200,000 mile cobalt....
Old Jul 6, 2010 | 10:55 PM
  #176
miked5426's Avatar
yes. copper...u got to. i usually do it every oil change or ever other oil change. i never notice any misfires...
Old Jul 7, 2010 | 09:12 AM
  #177
Tomtwtwtw's Avatar
Over time the chain can stretch and the tensioner can weaken. If you're lucky it will only jump a notch or two and your car will only run funny until you get a new chain. If you're not, it will jump more and knock your pistons into your valves.
It could be nearly a grand at the shop for parts and labor, but probably worth it if you're serious about keeping the car long term. And with a job like that, another 60 bucks on a 2 day rental won't kill you.
Old Jul 7, 2010 | 09:24 AM
  #178
cmatthewb101's Avatar
Really don't feel like going through all of the pages. How many miles are you up too?
Old Jul 7, 2010 | 10:34 AM
  #179
07cobalt2.2's Avatar
I believe he is up to like 190K or 187K or something.
Old Jul 7, 2010 | 03:55 PM
  #180
miked5426's Avatar
Every thousand i will update u guys. I just passed 188,000
Wouldnt i feel a difference in the car in the timing chain going bad ?
Old Jul 7, 2010 | 06:29 PM
  #181
myfakeevo's Avatar
no. its just one of those maintenance things that you should take care of every 100k, im actually surprised yours hasnt gone yet.
Old Jul 7, 2010 | 06:41 PM
  #182
miked5426's Avatar
SUPRISED? i think i'm more surprised at the wheel bearings haven't gone out LOL. especially considering that i had 20 inch wheels on thIS car for 3 years
Old Jul 8, 2010 | 01:01 AM
  #183
ebristol's Avatar
Take a pic of your odometer!
We got an RL on RLFs with 150k.
Old Jul 8, 2010 | 08:38 PM
  #184
myfakeevo's Avatar
mine went at 43k! lol
Old Jul 8, 2010 | 08:43 PM
  #185
RAIDERNATION 433's Avatar
i make sure i change mine every 3 k on the dot lol it only been done 3 time 9200 miles
Old Jul 9, 2010 | 07:44 AM
  #186
miked5426's Avatar
guys, i will post an odometer pic at 190k and then of course, at 200k
Old Jul 9, 2010 | 09:56 AM
  #187
ryaan's Avatar
you should send pics to gm at 200k, 250k etc. i think even theyll be surprised the car held up
Old Jul 9, 2010 | 07:36 PM
  #188
miked5426's Avatar
at this point they don't seem to really care . Ive sent a few emails to all heads n GM
Old Jul 11, 2010 | 07:01 PM
  #189
ptrblkz24's Avatar
That made me lol.Timing belts should be changed around 70,000 miles.Are u saying a chain is only gonna outlast a belt for 30,000 miles?A timing chain isnt a maintenance part.It should last the life of the car.It might stretch alittle bit,but the tensioners should pick up the slack.Unless u hear the timing chain slapping around,its fine.
Old Jul 11, 2010 | 08:51 PM
  #190
miked5426's Avatar
At this point, its not wirth it for me to fix things that aernt a problem. I know my car like the back of my hand...so ill know if something is wrong, even if its something small.
Old Jul 11, 2010 | 10:37 PM
  #191
08SSTCRD's Avatar
A timing chain is nothing like a belt, which is a piece of **** design. Hence the reason why even the Asians, which are always behind the times, are finally phasing them out after using such an inferior design for so many years. Timing belts require replacement on average every 75K miles, which can be damn expensive. Figure labor, timing belt, timing belt tensioner and idlers, crank and cam seals, water pump, oil, antifeeeze, and possibly a valve cover gasket, and you have yourself a $1,000 repair bill easily. Over 200K miles that can add up to between $2,000 and $3,000, every last penny of which you wouldn't have to spend if the car didn't use such a **** poor design in the first place.
Timing chains are designed to last the life of the engine under normal operating conditions. Under performance driving or heavy duty use, the timing chain may develop slack in which case replacement of the tensioner and/or timing chain may be necessary. Unlike belts, rarely do timing chains snap spontaneosly or require service. I don't think I've ever seen a car that required a timing belt service at 100k miles, except for a piece of **** Toyota Celica which had the chain snap and destroy the engine. No major loss there though, it was probably better off.
Old Jul 11, 2010 | 11:07 PM
  #192
myfakeevo's Avatar
thats because your both morons.
/end
Old Jul 11, 2010 | 11:14 PM
  #193
ptrblkz24's Avatar
/end
Huh?That made no sense.Learn how and engine works before u give advise to someone.
Old Jul 11, 2010 | 11:16 PM
  #194
08SSTCRD's Avatar
/end
Looks like someone just got schooled and can't take the heat, so you resort to name calling.
When you know your ass from a hole in the ground, come back and try to argue your worthless point.
Huh?That made no sence.Learn how and engine works before u give advise to someone.
He's obviously uneducated and very low on intelligence. Another stupid ricer on this forum, typical.
Old Jul 11, 2010 | 11:24 PM
  #195
ptrblkz24's Avatar
What scares me is that someone might actually listen to his advise.
Old Jul 11, 2010 | 11:27 PM
  #196
DC52NV's Avatar
/end
that's because you're both morons.
who's the moron?
Old Jul 11, 2010 | 11:35 PM
  #197
jthomas9's Avatar
subd
Old Jul 11, 2010 | 11:42 PM
  #198
Kahless's Avatar
im at 141... youre pulling away.
Old Jul 12, 2010 | 03:05 AM
  #199
Omega1x's Avatar
What r you at now? this is very impressive.
Old Jul 12, 2010 | 12:38 PM
  #200
miked5426's Avatar
Okwhy don't want you guys come n drive my car and see for yourself that the timing chain works perfectly fine. the car pulls like it was when i first brought it . i would be very surprised to see something like to go. just because it is not recommended does it mean it cant b done
189,000 just now....
