Which of the 3 wires for AC Pressure Sens.
Old Apr 26, 2011 | 05:59 PM
OttawaMark's Avatar
Is the 0-5v reference wire that talkes to the PCM?
Thanks
Old Apr 26, 2011 | 07:59 PM
OttawaMark's Avatar
17 GY 2700 A/C Pressure Sensor 5-Volt Reference
Service Information
Old Apr 27, 2011 | 09:26 PM
OttawaMark's Avatar
Nope, wrongo. That schematic is for an 2005 Cobalt...disregard if you have a later model as pin 17 is empty. Wrong one anyways, it is pin 26 on a 2005:
26 OG/BK 380 A/C Refrigerant Pressure Sensor Signal
Now which one is it on my 2007?
Old Apr 28, 2011 | 11:03 PM
ChineseWop's Avatar
I dont know what pin number it is but on my 06 on the blue plug that goes to the pcm (the top one) its the red/black wire. Should be the only one in the harness.
Old Apr 29, 2011 | 02:15 PM
5hizn1t's Avatar
Here's the info on the 2007 Cobalt A/C Refrigerant Pressure Sensor
LE5/LSJ engine:
Pin Wire Color Circuit No. Function
1 BK/WH 2751 Ground
2 GY 2700 5-Volt Reference - 1
3 OG/BK 380 A/C Refrigerant Pressure Sensor Signal
L61 engine:
1 BK 6256 Pressure Sensor Low Reference
2 GY 6255 5-Volt Reference - 1
3 RD/BK 380 A/C Refrigerant Pressure Sensor Signal
Below is the schematics of the A/C system. Sorry, it's a bit blurry. If needed, I can get a bigger, clearer pic of it.
Old Apr 29, 2011 | 05:03 PM
OttawaMark's Avatar
Well done 5hizn1t, that wins the thread.
Old Apr 30, 2011 | 08:54 AM
paddock's Avatar
OK.. I"m curious.. what was the point of this exercise??
Old Apr 30, 2011 | 09:27 PM
OttawaMark's Avatar
The point being was to use the 0-5v reference from the AC pressure sensor as a tap to log wide band through the basic version of hp tuners.
Old May 1, 2011 | 01:26 AM
paddock's Avatar
Is that the wire that I need to put a toggle switch on??? I've been trying to figure that one out for a couple weeks now!!!!
PM me details please!!??
Old May 1, 2011 | 10:09 AM
OttawaMark's Avatar
Yes, that is exactly it.
Crawl underneath, cut the orange/black wire coming from the refrigerant pressure sensor (small hands help) and splice two longer lengths on each cut end. Run those longer lengths to where you want your switch to be.
Get a 2input/1output switch, mine was actually 120v rated but works just fine.
Connect orange/black going to PCM to output on the switch.
Connect orange/black from AC sensor to one of the inputs.
Connect WB 0-5v output to the other input on the switch.
Voila, AC or WB logging but not both
Old May 1, 2011 | 10:34 AM
paddock's Avatar
so any three way toggle will work??
Old May 1, 2011 | 10:45 AM
OttawaMark's Avatar
Yep, mine was actually 120-240v rated but flows low volts through it with no degredation.
Old May 1, 2011 | 10:47 AM
paddock's Avatar
I'm guessing it's just a signal wire set up, so voltage might not be as much an issue..
Dude.. I can't thank you enough!!! My tuner guy has been so busy that he hasn't had a chance to get me the info for that switch set up. Many thanks!
Old May 27, 2013 | 05:15 PM
YelCal7's Avatar
Sorry to bring this thread back up. I have 3 way toggle switch, if I hook my Wideband on toggle switch where I hook up ground wire from Wideband to where ?
Old May 27, 2013 | 05:34 PM
OttawaMark's Avatar
Iirc, my WB ground wire is terminated to a bolt on the passenger side interior fuse panel.
Old May 27, 2013 | 06:04 PM
YelCal7's Avatar
I did that and it's a no go. Could it be blown fuse for A/C ? Or A/C turn off in my PCM ?
Old May 27, 2013 | 07:50 PM
YelCal7's Avatar
I have an 06 and I did checked my wires from A/C pressure sensor. It's Red/Black and I did what you did but for some reason it's not turning on. I use 1 wire from A/C sensor plugged to the top of the Rocker Switch, 1 wire go back to PCM go back to PCM go to the bottom of rocker switch, 1 from Wideband go to the middle of rocker switch, then last ground wire from Wideband hook on the metal. My Wideband still not turned on, it's AEM UEGO Wideband.
Old May 28, 2013 | 01:57 AM
OttawaMark's Avatar
When you say still not turned on, do you mean as in no power whatsoever?
Where are you getting your 12v power from?
The AC sensor wire you need to tap is but a 0-5v reference, resisted from a constant 5v power that you dont lol...I know this because I tapped the 5v constant first and couldn't figure out why my gauge read just fine but in HPTuners it was full lean. Anyways, tapping it all properly is moot if you don't have a 12v supply.
I tapped my IC pump power for the 12v, which itself was running off a spare fuse in the engine bay fuse box.
Old May 28, 2013 | 02:10 AM
YelCal7's Avatar
I use 12v from power outlet but can't figure how I hook that up to.
Old May 28, 2013 | 02:13 AM
OttawaMark's Avatar
Which power outlet?
And does the gauge light up? Or is it dark?
Old May 28, 2013 | 02:19 AM
YelCal7's Avatar
I had tried to do rocker switch with 5 pin relay, I can't get it work right. I attach Wideband ground wire to 12v ground wire n 1 go to 5 pin relay. It won't work, I took off from 5 pin relay and hook on rocker switch then it turn on. I did 5 pin relay hook on to rocker switch and I can hear click when I turn on rocker switch. It's a PAIN IN THE ASS! I am trying to figure out how ? Do I need to have ground wire from A/C pressure sensor ? I need to have wire diagrams to show me how to do this and get it working.
Old May 28, 2013 | 02:20 AM
YelCal7's Avatar
Originally Posted by OttawaMark
Which power outlet?
I did top power outlet. I custom made rocker switch to go there.
Old May 28, 2013 | 03:02 AM
OttawaMark's Avatar
Old May 28, 2013 | 11:34 AM
YelCal7's Avatar
This is GREAT! I will do that today! Alittle confused with Rocker Switch, White go to the Top, PCM go to the Middle, A/C pressure sensor go to the bottom. Right ? Just double check!
Old May 28, 2013 | 11:40 AM
YelCal7's Avatar
Your show Orange/Black but I checked mine is Red/Black from A/C pressure sensor. Mine is 06.
