Which of the 3 wires for AC Pressure Sens.
Old May 28, 2013 | 11:56 AM
OttawaMark's Avatar
Red/black is the one, different colours based on years and even engine type.
As for the switch, that sounds right.
Old May 28, 2013 | 12:14 PM
YelCal7's Avatar
Awesome Man! Thank You So Very Much! I will let you know the update.
Old May 28, 2013 | 03:31 PM
YelCal7's Avatar
Ok, It's Working! But the thing is the switch won't turn off for Wideband. It's like both r turn on at the same time.
Old May 28, 2013 | 03:42 PM
YelCal7's Avatar
I have to plug off the fuse to turn off Wideband.
Old May 28, 2013 | 04:58 PM
YelCal7's Avatar
Is there another way that I don't have to pop the hood just to plug on n off fuse ?
Old May 28, 2013 | 06:55 PM
OttawaMark's Avatar
You need to connect the 12v power to a 'key on' fuse slot, both fuse boxes have a spare, empty key on you can tap into and are easy enough to find if you have a multimeter.
Old May 28, 2013 | 07:09 PM
YelCal7's Avatar
FWAK! I know what You are talking about. Can I go wire up where the Wiper Fuse ? The thing is I don't see rocker switch light up when I turn it on.
Old May 28, 2013 | 07:19 PM
OttawaMark's Avatar
I used the spare one in the passenger side compartment under the dash along the side of the trans tunnel where the shifter sits. If the wipers are key on then those would work just fine.
Old May 28, 2013 | 07:30 PM
YelCal7's Avatar
Hey! I saw Advance Auto has an extension for fuse with wire. Maybe I should hook that up to wiper fuse cause that's where it turn on and off. LOL!
Old May 28, 2013 | 07:52 PM
YelCal7's Avatar
This 1 I am talking about, here's link->Mobile: Buy Bussmann ATM Fuse Tap - 10 Amps BP/HHH-RP at Advance Auto Parts
Old May 28, 2013 | 09:06 PM
  #36
OttawaMark's Avatar
That is sexier than my setup, might even look for a couple of those myself!
Old May 28, 2013 | 09:08 PM
  #37
YelCal7's Avatar
LOL! I found those at Advance Auto, I am gonna do this!
Old May 29, 2013 | 01:42 PM
  #38
YelCal7's Avatar
Ok, I did fuse tap. It works GREAT! As for rocker switch that's what I am confused, it don't light up when I switch it on. Does that means I have to do tune to split the voltage between A/C pressure sensor and Wideband ? Right ?
Old May 29, 2013 | 09:29 PM
  #39
OttawaMark's Avatar
It needs to be a 2 channel rocker switch, either the PCM is seeing 0-5v from the AC sensor or the WB sensor. There is no splitting voltage. Never used a switch that lit up so can't help you there.
Old May 30, 2013 | 12:50 AM
  #40
YelCal7's Avatar
That's what I have 2 channel rocker switch with 3 outputs. Just don't understand why it won't turn on. Send me link of what You are talking about.
Old May 30, 2013 | 12:56 AM
  #41
YelCal7's Avatar
That's what I have. Link->http://www.ebay.com/itm/Round-rocker-switch-lighted-on-off-red-12v-USA-SELLER-/200813506069?pt=LH_DefaultDomain_0&hash=item2ec16aee15&vxp=mtr
Old May 30, 2013 | 12:58 AM
  #42
OttawaMark's Avatar
This is what you need:
Old May 30, 2013 | 01:01 AM
  #43
OttawaMark's Avatar
That third terminal on the switch you have is a ground, basically you have an on-off switch and you need a 2 way instead. No ground on the 2 way, middle terminal is the destination and the terminals on each side are the channels.
So, switch to 1 means the PCM reads AC sensor, switch to 2 means PCM reads WB.
Old May 30, 2013 | 01:03 AM
  #44
YelCal7's Avatar
Does it have round 1 ? Where I can get those ?
Old May 30, 2013 | 01:15 AM
  #45
YelCal7's Avatar
Found it in Ebay the round 1. Link->http://www.ebay.com/itm/2x-3-Position-Round-Boat-Rocker-Switch-AC-6A-250V-10A-125V-3-Pin-SPDT-ON-OFF-ON-/321026999633?pt=LH_DefaultDomain_0&hash=item4abeb34551
Tupp
2.2L LAP Performance Tech
Jan 2, 2016 12:04 PM
dennis69
Oct 20, 2015 07:39 AM
no_ss
Oct 18, 2015 11:58 PM
ernnyyes
Oct 2, 2015 05:16 PM
jmelton327
Sep 26, 2015 10:04 PM
