5 or 6 quarts of oil?
I did a oil change and new filter i put 5 quarts in then started the car and checked oil it needed another quart... so is it 5 or 6 quarts.....
i did a search and some say 5 quarts and others say 6
Manual says 5 quarts..... i need advice
______
______
Originally Posted by NJBLUESS
NO, only 2.0L, 2.2 is 5. Sorry for not clarifying and over looking yours is a LS.
Tha is correct. I just did an oil change on my gf '03 Cavalier with the 2.2l Ecotec and took 5. I did an oil change in my SS/SC and it took 6
Always go by what your owner's manual says. That way there will be no complications with the dealership if something happens and they ask how much oil you put in the car. Beteter safe than sorry.
I work at a dealership, trust me and use the owner's manual.
Red_Wing_2121
Red_Wing_2121
I also work at a dealer and there are always misprints in owners manuals just like the misprint in the SS manual about the oil.
Red_Wing_2121
Originally Posted by eastcoastz
5 puts it 3/4 to full on the stick which is where it should be.
yeah thats what confused me....im not used to this kind of dipstick.... it says in the maual.. if the oil is in the middle of the dip stick thats full...
__
For the 2.2L plan to buy 6 quarts !!!
Mine took about 5 and a half quarts.
The oil level line is right below the top of the dip stick marker when the engine is hot.
And Don't forget to reset the Idiot Oil Monitoring System.
Originally Posted by 05BurntOGSL
My car has 3500 miles on it (changing oil this weekend) and it say's 55% Oil Life Left, how the HELL is that possible?
That's about right.. I had 5600mi on my car when i changed my oil and it was on 32%
Originally Posted by p7x
the supercharger needs 1.
It's 5 quarts when the dealer changes my oil and I have checked the dip stick and it's full. I don't know where ppl get the idea that it takes 6+ qts of oil.
So lets review:
1) Owners manual 5 qts
2) Service manual 5 qts
Ok so where does this 6 qts come from
Now I don't doubt that the engine will take 6+ qts of oil and show full on the dipstick but that doesn't mean it is supposed to have 6 qts in it.
start the car then check it.... it will say half full
____
if you dont put 6.5qts in youll be sorry
With out a doubt its 6.5 qts of oil, i pretty much do oil changes all day and i did my own on my ss s/c... put in 6.5 qts.. start the engine, turn it off(fills up the oil filter) and youll notice that 6.5 qts is perfect
(FOR THE 2.0L s/c only)
5 quarts DOES NOT REGISTER ON THE DIPSTICK!
I just changed my oil this past weekend. 5 quarts doesn't make it to the measurement part of the gauge. Then, when you start it, IT DOESN'T REGISTER ANYMORE PERIOD.
6 quarts put it halfway up the gauge. Not empty, not full. Seems pretty damn safe to me. 6.5 quarts will get to the full line.
The owners manual is wrong, plain and simple. Anyone with automotive experience who has changed the oil on the SS will tell you so.
I would NOT reccommend having only 5 quarts of oil in there. Maybe not all these cars are the same, but has anyone with 5 quarts had the dipstick read OK levels? I wouldn't think so.
people forget the oil filter has to absorb oil into as well. so if you put in 5 qts the oil filter may hold a 1/2 qt (im guessing, not totally sure how much it may hold) so in order to make up for the loss that was absorbed into the filter you have to add some oil so it will read on the dipstick. when i put in 5 qts it didn't register as well on my car so i added a little bit at a time and checked the dipstick until i was satisfied where it was. on a side note when i poured the OLD oil from the car back into the empty containers it FILLED UP 6qts. one 5qt jug and one 1qt bottle.
importkiller
Sep 30, 2015 07:18 PM
