Aeroforce gauge
Old Sep 13, 2013 | 08:39 AM
395 plus's Avatar
Aeroforce gauge
I have a cobalt SS (LNF) and when I monitor all cylinder misfires on the aeroforce gauge it will have numbers all the way for 6 cylinders. Does everyone elses gauge do this too? I have the Dual intercepter setup. I figured it should only show 4 if you have a four cylinder engine.
Old Sep 13, 2013 | 09:13 AM
yellowsupercharged06's Avatar
i bet if you searched you can find your answer .. hint ... hint
Old Sep 13, 2013 | 09:51 AM
395 plus's Avatar
I did!!!! I searched Aeroforce and find lots of forsale threads. And a couple other threads about the gauges but none with an LNF and the way the display reads misfires. So if you know the answer then just say it.
Old Sep 13, 2013 | 11:31 AM
r3v07ut10n's Avatar
http://www.aeroforcetech.com/files/I...AL_rev_5_2.pdf
page 11 H:
electing this option will bring you directly to a display where cylinder misfires are displayed in real time and reset about once per minute. There will be fields for 8 cylinders irregardless of how many your particular vehicle has. If you have a 4 cylinder only pay attention to the top 4misfire fields, for a 6 cylinder, the top 6. This option is not available on Fords as it is not supported. For those with dual units, this function will not work properly while the other gauge is in scan mode. Therefore, place the other gauge in its menu mode before activating the Misfire mode.
Old Sep 13, 2013 | 10:30 PM
395 plus's Avatar
thank you that explains it.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Jan 12, 2016 12:01 AM
ineedacobaltss
Nov 7, 2015 02:25 PM
Sep 27, 2015 08:53 PM
