Anti abuse programming?
Old Jun 12, 2005 | 06:18 PM
MarcS's Avatar
The Stig
Had something interesting happen to me today.
I was pulling up to a stop sign on a hill with a car in front of me. I wasn’t paying attention and when I stopped to roll up to the stop sign I embarrassingly bogged it pretty bad and almost stalled, but I recovered it. The strange thing was when I recovered I was not able to bring the clutch pedal back up. It stayed down disengaging the clutch so I could not put it in gear. I was able to roll to the side of the road where I let it sit for a few mins and it then worked fine.
This is my first year driving a stick so I tend to make the rare mistake now and again but I never experienced anything like this before.
Old Jun 12, 2005 | 07:13 PM
Maven's Avatar
the clutch is not electronically controlled in any way....if your pedal stayed down and the vehicle wouldnt move with a gear selected you should see your dealer.....
Old Jun 12, 2005 | 08:25 PM
MarcS's Avatar
The Stig
it works fine now, hmm no idea what went on then.
Old Jun 12, 2005 | 11:14 PM
wesmanw02's Avatar
I'd still take it into the dealer and have them check it out, especially if it does it again. As Maven mentioned, the clutch is in no way electronically controlled or linked to the ECU/PCM.
Chances are there's a problem with the clutch itself, probably with the hydraulic system. I've heard of this happening on other cars and having the system not recover, definitely take it into the dealer and have them take a look at it.
Good luck, let us know how you make out.
Old Jun 13, 2005 | 12:10 AM
MarcS's Avatar
The Stig
lol well that scares me a little, I'll have them look at my clutch when I have the oil changed. I also have to show them my paint defects. It seems pretty common for cobalts to have spots in the paint.
A kid in my town has a red SS and he pulled up at the gas station where I was filling up and we talked about the cars for a few and pointed out the defects in the paint on each of our cars.
Old Jun 13, 2005 | 09:29 AM
codyss's Avatar
Sounds like air entered the system or the cluctch itself got hung up.
The 1998-2000 F-Bodies had junk Hydraulics and during spirited running the clutch would get stuck on the floor.
The 2005 Cobalts do have a program that decreases performace when the computer senses constant abuse. But your problem is unrelated.
Old Jun 15, 2005 | 08:11 PM
tiny's Avatar
really??
what is the criteria for that?
Old Jun 15, 2005 | 08:29 PM
zinner's Avatar
Moderator Alumni
Originally Posted by tiny
really??
Limp mode. A couple people have reported it. Basically if the car senses trouble with the engine/powertrain it reduces the output of the engine. I am not sure what the criteria for the status of the engine must be before it's engaged, but I think it basically keeps you from going over 1/4 throttle.
I don't think it's abuse related, more of the engine is too hot, or there isn't enough oil pressure, ect.
Old Jun 15, 2005 | 08:47 PM
Mike_42's Avatar
... the clutch is in no way electronically controlled or linked to the ECU/PCM.
However, doesn't the Cobalt have the requirement for you to press the clutch to start the engine ? so is it not true that the computer does know if the clutch is pressed or not? (indicating at least a sensor of some sort does monitor the clutch itself or the clutch pedal so that it will not crank unless it is pressed.)
I agree that there wouldn't be any type of control that would ever 'hold' the pedal in...
in any case, I hope it doesnt become a problem, and I also would say if it ever happens again to take it right to dealer if possible.
_
Old Jun 16, 2005 | 12:23 AM
CobaltSS422's Avatar
I believe all MT cars need to be started with the clutch in. Not sure why.
Old Jun 16, 2005 | 03:08 AM
mafsu's Avatar
I'm sure it's to prevent what we used to call "lurching" the car when you start it. Imagine being in the mall parking lot, in a hurry. Jump in the car, hit the ignition and bam the car jumps forward into the car parked in front of you. A funny (as long as it's not you) experience that was not uncommon to see back when I first started driving.
Old Jun 16, 2005 | 06:57 AM
socalcobalt's Avatar
i had an old 87 comanche dessert runner that started without clutch depression
Old Jun 16, 2005 | 09:06 AM
codyss's Avatar
The Anti-Abuse programming has preset conditions to determine if a abusive manuver is being performed. The Cobalt SS has it just like the 1998-2002 F-Bodies did.
Old Jun 16, 2005 | 03:39 PM
Gillto's Avatar
Under the clutch pedal is a little switch which gets depressed when you push the pedal down, called the neutral safety switch. The engine will only start if that little switch is depressed. So it is not actually part of the clutch.
Old Jun 16, 2005 | 08:35 PM
tiny's Avatar
also note, some cars have a clutch override button that you can use to start it
although i have no idea how that works
Old Jun 17, 2005 | 08:04 AM
Maven's Avatar
I have never understood GM's clutch override feature on some vehicles, but its just a button that when depressed allows you to start car w/out pressing clutch.....kinda dumb...I mean you have to push the clutch to get into to gear and to get going smoothly once your started so the switch always seemed like an EXTRA step to me...whateva'
InfraRedline
Drag Racing
35
Sep 29, 2015 02:09 PM
reybalt
Sep 27, 2015 07:57 PM
Sean Cummings
Sep 11, 2015 09:35 PM
Highgross89
20
Sep 11, 2015 03:24 PM
Jacque8080
Sep 9, 2015 09:21 PM
