Anybody a painter??
Old Oct 5, 2009 | 10:55 PM
BARBER_IMAZE's Avatar
Anybody a painter??
So im interested in learning to paint.
i just bought a paint gun today and i know some stuff that ima have to buy
but i want to know all the materials ima need.
like primer, paint, paint thinner, clear, hardener??
any advice?
Old Oct 5, 2009 | 11:02 PM
06'BaltLS's Avatar
a paint mask at the least when you paint...if not a whole suite, unless you want all them VOC's from the paint in your system lol....tack cloths for in between coats, stuff for wet sanding, buffer, compounds, filters, mixing cups...all kinds of stuff lol
Old Oct 5, 2009 | 11:04 PM
lol yeah i dont plan on dying while painting ha.
thanks for the advice..
i heard about two ways of getting paint but im not sure.
i heard you can buy the paint thats all mixed already
or you make your own? is that true??
Old Oct 5, 2009 | 11:07 PM
06'BaltLS's Avatar
i would mix it yourself....its not that hard to mix it, the mixing cups usually have all the ratios and lines to fill to....and find something you can spray to check your pattern also...
Old Oct 6, 2009 | 10:00 AM
alright. thanks really appreciate it...
Old Oct 6, 2009 | 10:13 AM
kburgess04's Avatar
you need alot of patience. my advice is to find something you can paint that doesnt have alot of metallic in at first. just so you can get the basics down. overlap your pattern by half. if you want the metallic to really stand out, do thin coats. if you want light metallic do heavy coats. make sure your air supply has a mater seperator. or even one that is hooked to the regulator on your gun. buy 2 different guns one for primer and one for paint/clear. paint and clear gun get a smaller tip.
Old Oct 6, 2009 | 10:16 AM
BYT*SS*TURBO's Avatar
Buy cheap generic base/clear to start, get some test panels and play around a lil. You can try diff amounts of reducer, diff air pressure, spray width etc... Prolly the best way IMO!
Old Oct 6, 2009 | 06:05 PM
well i have a couple friends who said to practice on their rims..
i've painted with cans and theyve came out very nice. just took my time and did alot of preparing and then painting.
but i know i could learn pretty fast..
I also heard that i should buy the paint thats already mixed together. Is that a good way to start??
and then just have primer, and clear?
MikeK
How to Guide
22
Jul 24, 2010 08:28 PM
Turbo Wax
TurboWax
30
May 5, 2010 10:48 AM
ddsscobalt
Mid Central
Oct 31, 2009 11:21 AM
