Anyone setup a manual radiator fan switch?
Old Jun 27, 2007 | 11:25 AM
TCarter's Avatar
Just as the title states.
Has anyone settup a switch to manualy turn the radiator fan on?
If so, what wires did you tap into?
Id like other members input before I go splicing wires.
Old Jun 27, 2007 | 11:29 AM
BriantheLion26's Avatar
I would like to know as well so when I take it to the track I can keep it a little more cooler. I would also like the intercooler pump to run but I think that is more involved. If it isn't too difficult I would like to try it. Cooler the better.
Old Jun 27, 2007 | 11:31 AM
Doc's Avatar
Doc
search for fans and wopontour and there is an awesome thread.
Old Jun 27, 2007 | 11:38 AM
thought's Avatar
I just used a temp sensor and relay. The tempsensor goes in between the rad blades. The sensor.relay kit can be found at any parts store I would think
EDIT: I see this wasn't a "how to install a fan switch" but "how to turn it on manually"......I guess you'd need some wiring diagrams......Crate Engine Depot for the owners manual???
Old Jun 27, 2007 | 03:58 PM
HunterKiller89's Avatar
theres a nice trick i learned on the forum...someone else posted it and i tested it out and it works
if you turn the AC on, leave it for like 10 seconds, then turn it off, the radiator fans turn on and wont turn off until the coolant is 185 degrees or lower
Old Jun 27, 2007 | 04:10 PM
kanabrewski's Avatar
https://www.cobaltss.net/forums/show...ight=wopontour this thread will help
Old Jun 27, 2007 | 04:33 PM
shawn672's Avatar
NewEraPerformance, a performance shop here in Rochester, NY installed one, he's a member here and may be willing to help ya
Solaris99
28
Mar 15, 2017 01:22 PM
patooyee
Oct 15, 2015 05:11 PM
OrangeCoba
Oct 1, 2015 10:00 PM
Tupp
Sep 30, 2015 08:18 PM
