Boost Gauge
Boost Gauge
Is the stock boost guage covered under the warranty or do i have to go buy my own...if i do,anyone reccomend a nice one that looks almost like stock but mechanical.found this one...looks almost like stock,and its mechanical
http://allcargauges.com/product.php?productid=9126
Not too sure...If you didn't do anything to it, I wouldn't see why they would have too much of a problem replacing it. You may want to look aftermarket though, cause our factory boost gauge isn't too accurate when it is working right. lol
OR buy a nice stock one yourself..?
http://www.crateenginedepot.com/stor...uges-C212.aspx
Are you 100% sure the problem is in the guage itself? If so I'd insist the dealer replace it, there's no way you can break that **** on your own - sans hammer.
Boost gage woes...
The dealerships WILL cover the gage if it is a result of normal wear or the factory's common foul up. The routing of the wiring harness caused trouble for a large number of gages out there, it would just cut out to 0 and not read. This isn't what your problem is but it may have a similar solution. Def check with the maintenance dept at your dealer.
i aint payin 50 bux for a stock gauge..ill go an mechanical autometer
you COULD have a vaccume leak. If the guage is actually working then it should be ok. Last time I checked boost guages just worked off of reading the vaccume so if you had a small knick in a line somewhere, your manifold's cracked, bad intake gasket, etc. it would cause the guage to read off.
I'm assuming the stock boost guage actually reads off the vaccume and isn't electrical, but either way if you had a vaccume leak there'd be a problem with it.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
