Brembo pad wear issue
Old Jul 11, 2013 | 03:16 AM
footballplaya3k's Avatar
So I changed out my front rotors and pads a couple days ago and it appears I am having uneven west issues. 3 out of the 4 pads wore completely evenly but the outside pad on the driver side was worn down much further.
The 3 evenly worn pads had probably 3/8 of an inch of pad left while the one that wore unevenly was basically down to bare metal.
Rotors weren't warped or anything. I have no idea what would cause this. Any idea?
Old Jul 11, 2013 | 10:17 PM
Nothing?
Old Jul 11, 2013 | 10:20 PM
Might want to bleed the brakes powell posted the correct bleeding order in Sox-Fans thread about his brakes
Old Jul 11, 2013 | 10:27 PM
randomname's Avatar
Check to see if the slide pins are frozen.
ssyellow's Avatar
Could maybe have a bad piston? I remember my friend needed an extra Brembo I had and was going to put on my Redline because his died.
Old Jul 11, 2013 | 10:34 PM
randomname's Avatar
A bad piston would cause no pad wear. If one of the slide pins are seized (or both) that would prevent the caliper from traveling properly. This would cause the caliper to unevenly slide and it would wear the pads on an angle. I had this issue with a Dakota I had and my caliper actually angled itself so much that it was grinding on the inside of my wheel! Haha
Old Jul 11, 2013 | 11:14 PM
DillySS's Avatar
I didn't know the front brakes had slide pins.
Old Jul 12, 2013 | 08:42 AM
silvercharged's Avatar
The pistons while being pushed out also pull back in slightly when pedal is released. It could be a bad piston not releasing like it should.
Old Jul 12, 2013 | 08:54 AM
ssyellow's Avatar
Thats what I was thinking. Hopefully its not too common, I was surprised when my friends was seized.
Old Jul 12, 2013 | 09:11 AM
mike1coolguy88's Avatar
brembos r fixed calipers they dont slide on pins, sounds like you have air in the caliper.
Old Jul 12, 2013 | 12:42 PM
randomname's Avatar
Damn, looks like I need to read up about cobalt brakes haha.. My bad OP. Too much GTO knowledge rolling around in my head!
Old Jul 12, 2013 | 01:34 PM
Powell Race Parts's Avatar
Pads get seized in the calipers bridge it's a mono block caliper. The pins can be seized but the pads are not sliding on the pins. Strip
And rebuild lotsa dough
Old Jul 12, 2013 | 02:05 PM
LNFTX's Avatar
Listen to Powell take the pads out cleaning grease everything really good I had the same problem I let it go too long and it cost me $150 set of pads and a hundred dollars set of rotors cleaned everything real well never had a problem again
Brake dust was keeping the pad from fully retracting
Old Jul 13, 2013 | 09:10 PM
I bled the system very well. No air but lots of dirt in the first bit that came out. Pins weren't, aren't seized. I cleaned and lubed them pretty good. I will take the caliper off a thoroughly clean it on Monday, hopefully that fixes it.
Jan 12, 2016 12:01 AM
deviance
Nov 24, 2015 05:51 PM
Trav3480
Oct 1, 2015 08:17 PM
Tupp
Sep 30, 2015 08:18 PM
grampss
Sep 27, 2015 08:51 PM
