Camshaft Positioning sensor code
chevycobaltforum .com/forum/f9/exhaust-camshaft-sensor-code-5800/
long story short ive had 5 Camshaft Positioning sensor codes thrown in a matter of about 18mo. the first one happened while i was cruising down the freeway and after an oil change and clearing the code from the ECU no issue. within the last month or so it has happened an additional 4 times which kind of raises a flag to me to be concerned. the first time it happened the code i got was P0014, then recently it was P0010 and P0011 three times. after the last time it threw a code the car started acting funny. it wouldnt start on the first attempt but rather the 3rd. and now it somewhat feels like its learching forward and when in park the motor seems to rev from 700 to 900 back and forth. sometimes it clears itself up and sometimes it just keeps going.
2009 cobalt LT auto bone stock.
i have not, are they in need of replacing? the first time this happened i was shown this article GM#PIP4469F: Intermittent DTC P0011 And P0014 P0016 P0017 - Cobalt SS Network and thought maybe it was just muck in the oil. now that its thrown the codes 5 times im slightly concerned. thanks for your input
thanks for the help guys. looks like the car might be needing a bit of tlc, just about at 85k miles. anything else i should look at doing that most likely hasnt been done as far as tune up like tranny fluid/filter, timing belt, and such. would like to order anything i need at once if i need to service anything.
just getting around to ordering the sensors and i just want to make sure that im ordering the right part. rockauto says i need a sensor that looking like thishttp://www.ebay.com/itm/HERKO-CAMSHAFT-POSITION-SENSOR-PCH655-FOR-BUICK-CHEVROLET-SAAB-PONTIAC-05-11-/380876604681?pt=Motors_Car_Truck_Parts_Accessories&fits=Year%3A2009%7CMake%3AChevrolet%7CModel%3ACobalt&hash=item58ae03c509&vxp=mtr but the one on my car looks like this one http://www.ebay.com/itm/Cobalt-HHR-Pursuit-2-2-2-4-Intake-Camshaft-Position-Actuator-Solenoid-12655420-/380996528801?pt=Motors_Car_Truck_Parts_Accessories&hash=item58b529aaa1&vxp=mtr the not sure if the angle of the plug matters but they kinda look different. input please
its been roughly 2-3 weeks and 300 miles or so since i replaced both camshaft sensors. yesterday after changing the oil we drove about 30 miles and while at a stop light the car was trying to learch forward, almost like i was holding the brake and hitting the gas at the same time. it felt kind of rough. got to where we were going and turned the car off, once i turned it back on the check engine light was on yet again and the code was P0014 yet again. is it possible that ive got a problem with the car/wiring or got a bunk sensor? seems odd id get the same code thrown 3-5 times in the last efw months. on a side note my oil filter looked odd when i pulled it out, almost like it was crushed slightly. picture below
just getting around to ordering the sensors and i just want to make sure that im ordering the right part. rockauto says i need a sensor that looking like this cps#1 but the one on my car looks like this one cps#2 the not sure if the angle of the plug matters but they kinda look different. input please
Which sensors did you replace, the ones on the top of the valve cover are not sensors, they are solenoids which actuate the VVT phasers on your car. Common issue that they go bad and they throw those codes, and also disable the traction control in the process. The two black sensors bolted to the right side of the head on the front and back are the camshaft position sensors. Not as common that they fail.
these are what i replaced. i made sure i installed them in the proper places. so is it possible that the sensors on the right side of the head the culprit throwing the codes?
