can't turn key sometimes...
so sometimes i get in my car to turn it on (obviously) and the key goes in the hole, but i can't seem to turn it. totally stuck. and then finally after screwing around with it for a few minutes itll let me turn the car on finally. what is the cause of this phenominon? doens't happen all the time but i'm afraid its gonna leave me stranded sometime soon if i don't nip it in the bud
One really common thing is the steering wheel is slightly turned. If it's just slightly turned sometimes the wheel locks with a little tension on it and you won't be able to turn your key. If it happens again try turning your wheel slightly one way or the other and see if it helps. If not, there's a recall on some cobalts that have faulty ignition cylinders. The only way to fix it is replace it with the new design that don't fall apart like the original does.
I've sold many of the new designs for Cobalts, HHR's and Cadi CTS
roth
Sep 26, 2015 12:16 PM
