Case re-learn and crank sensor position re-learn
Old Sep 26, 2008 | 10:15 AM
blackss2.0's Avatar
Is it necessary to do this if i throw in a used pcm with a stage 2 on it???
BUmp
Last edited by blackss2.0; Sep 26, 2008 at 10:15 AM. Reason: Automerged Doublepost
Old Sep 26, 2008 | 12:02 PM
blackss2.0's Avatar
zzp pcm crank case relearn??
I have a stage 2 pieced together and just need a tune. if i get a zzp pcm do i need to get a crank case relearn or is it just plug in play? Thanks
Old Sep 26, 2008 | 12:06 PM
Psykostevo's Avatar
You need the case learn. A dealer can do it, and it can usually be done through HPTuners too.
Old Sep 26, 2008 | 12:09 PM
umrdyldo's Avatar
Can someone explain how this works?
I have the option on my DashHawk and was wondering if it just reset the computer or what?
Old Sep 27, 2008 | 02:52 AM
maverick0716's Avatar
It's pretty simple. You just tell the dashhawk you're doing the case relearn. Turn the engine on.....let it idle for a sec. Bring the rpms up to 4000 gradually, then you will feel the engine all of a sudden want to rev.....immediately let off the gas and let the rpms go to idle. That should work and the check engine light should go out.
Old Sep 27, 2008 | 02:56 AM
mrsilent13's Avatar
hmmm interesting....i need to get a dashhawk now or since i was one of the first to get tuned by vince from trifecta...have him clear this out.....but not worried about it right now since my car is still down. but i should be up and running sometime after oct 3rd
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Tupp
2.2L LAP Performance Tech
Jan 2, 2016 12:04 PM
Stuff
Oct 1, 2015 05:47 PM
cw383
Sep 30, 2015 12:41 AM
jmelton327
Sep 26, 2015 10:04 PM
