Chamber kit?
Old Sep 18, 2006 | 12:42 PM
mkulrey13's Avatar
Chamber kit?
Dont even think i spelled it right but anywho, ive been told i need one with a sportline drop, and ive been told i dont them it. I have an LS sedan. should i get it and also what are the advanages?
Old Sep 18, 2006 | 12:47 PM
rally's Avatar
its CAMBER and you shouldnt need one
Old Sep 18, 2006 | 12:59 PM
roccityroller's Avatar
get an alignment and you'll be fine.
Old Sep 18, 2006 | 01:13 PM
CTCOBALTSSS's Avatar
Yes get a camber kit aspecially with an LS. The camber kit corrects the pitch of the wheels so that you don't get bad uneven tire wear. Get it, I have one, trust me your tires and wallet will love you for it a year from now. Best $20.00 you can spend. Don't forget to get an alignment too.
Old Sep 18, 2006 | 01:40 PM
mkulrey13's Avatar
can i put install the springs now and get an alignment and maybe 2 weeks later get the camber kit and have it installed? how hard is it?
Old Sep 18, 2006 | 01:43 PM
c0baltic's Avatar
install the springs now get the alignment now also it's not much. you can get the camber kit later like i did no biggie. but you need to align the tires after the drop or else your donna wear your tires bad and/or your steering will be off.
-drew
Old Sep 18, 2006 | 01:45 PM
mkulrey13's Avatar
whats it called. brand or anything?
Old Sep 18, 2006 | 01:46 PM
IMADreamer's Avatar
You should get an alignment the day you drop the car. Why would you spend all that money on springs and not go the extra mile to get the camber kit and alignment? It only makes sense. If you are going to mod, do it right. Just save up a few extra pennies, you will thank yourself later.
Old Sep 18, 2006 | 01:55 PM
mkulrey13's Avatar
um im am getting an alignment the day i drop my car.. when did i say i wasnt? also i wont have the camber kit by the time i drop it so before you go flamming know the facts.
Old Sep 18, 2006 | 01:59 PM
Listerman's Avatar
you needed to state the facts first, no one is going to flame... a camber kit is like a condom... you dont necessarily need it but its being safe.
Old Sep 18, 2006 | 02:01 PM
mkulrey13's Avatar
well put but i can install it like week or 2 after i lowered the car tho correct.
Old Sep 18, 2006 | 02:03 PM
c0baltic's Avatar
yea. thats what i did .. when i dropped my car i didnt have it nor did i see a sense in having it cause the tires looked straight but down the line i just figured i'd pick one up and throw it on just in case
-drew
Old Sep 18, 2006 | 02:18 PM
IMADreamer's Avatar
sorry, I read the post wrong. I thought you were saying you were getting the springs installed and then two weeks later get the alignment and camber kit. I wasn't trying to flame you I was just saying that you should do it all at once. Sorry for the misunderstanding, in case you haven't noticed by the way I type I have the tendancy to mix words up and rearrange them. I also do this when I read. I can't help it, it's a learning disability I have struggled with forever. Again, sorry I wasn't trying to flame, I was just trying to be helpful.
Old Sep 18, 2006 | 02:41 PM
mkulrey13's Avatar
NP dreamer Much <3
Old Sep 18, 2006 | 03:02 PM
mkulrey13's Avatar
Does the camber kit include 2 bolts per strut or one bolt per strut?
Old Sep 18, 2006 | 04:20 PM
Halfcent's Avatar
I'm old school
I have a dropped base coupe, just like what you want to do. You do NOT need a kit. I had it just in case it was needed at the time. You don't install the kit when you install the springs. You bring it with you to the alignment, and if the adjustments that need to be made exceed the cars limits, then the guy doing the alignment will use the kit. The kit has 2 bolts, one per wheel. However, the camber on the Cobalt is not adjustable like most cars. It is factory set. The holes in the struts for the bolt have no adjustability. You will however still need an alignment for toe adjustment. That simply involves resetting your steering tie rods, a completely different thing. My alignment, from GM, after installing my springs cost me $50. Do not drive your car around after installing your springs without getting the alignment done. I realize you want to work on your car, but do it right the first time.
Old Sep 18, 2006 | 05:10 PM
rally's Avatar
now I feel smart because halfcent backed up my claim, haha. Anyways I have Tenzo's on my LS and I didnt need a camber kit, my alignment was not off and I've had no problems. I've put about 3k on my balt since lowering, and I routinly check my tread wear. The tires wear evenly across the entire surface.
Old Sep 23, 2006 | 05:14 PM
jimbos'ss's Avatar
i tend to disagree i think the camber kit is necessary, i've put cloe to 15k miles on my balt since i dropped it and my tires are not wearing evenly , and yes i had my car aligned. i just bought the camber kit from ingalls and it will go on tomorrow.
Old Sep 23, 2006 | 09:39 PM
Halfcent's Avatar
I'm old school
It's not a matter of weather or not you agree. Did you get an alignment? Was the shop able to align it properly? Then you don't need the kit. If you didn't get an alignment, that's the problem.
thewafflesareburnt
Sep 30, 2015 02:29 AM
yellow dragon
Sep 28, 2015 09:49 PM
Sep 28, 2015 12:51 PM
metroplex
Sep 27, 2015 07:48 AM
