clutch
Old Mar 2, 2008 | 10:17 PM
killah_thug08's Avatar
clutch
i have a question, or if someone knows this is true, is our stock clutch holding us back on how much power we get wit bolt ons and stage kits? my friend got 2.8 pulley 60lbs , belt ,spark plugs and hp tuned (by a very well know guy that does good work) and he got 266whp than he just decided to change his clutch because he did not like it and installed a spec clutch and went to the same dyno and got 278whp, i dont understand.......... and weather was around the same
Old Mar 2, 2008 | 10:18 PM
Coblt ss super's Avatar
If he put a lightweight flywheel than yeah he gained power
eurochevy's Avatar
he coulda had a clutch that was **** and slipped briefly?...and weather does a lot
bigrroberto's Avatar
yeah the lightweight flywheel would have came with it so.
Old Mar 2, 2008 | 10:20 PM
craigk_c19's Avatar
dang i want a flywheel and new clutch now :P
Greased's Avatar
12 hp from a light weight flywheel?
i dont know much about transmissions just wondering if someone could confirm that
Old Mar 2, 2008 | 10:22 PM
his stock clutch was pretty much looking new when he took it out.
ya same thats why i wondering...
Last edited by killah_thug08; Mar 2, 2008 at 10:22 PM. Reason: Automerged Doublepost
TurboTechRacing's Avatar
A slight change in atmospheric pressure could change that.
Also if he did have an aluminum flywheel installed with the clutch, 10 HP is a good increase to see with an aluminum flywheel.
If anyone is interested in SPEC items, PM us we will get you a good price.
Red2.4SS's Avatar
I have heard that it won't change your dyno results, but not certain. It gives more gains in the lower gears I know that.
Old Mar 2, 2008 | 10:24 PM
Unless his stock clutch was slipping, and now with the new one it holds the power, so it is showing the true HP that the engine is making.
Old Mar 2, 2008 | 10:25 PM
his clutch wasnt slipping he had about 6k km on his car
Old Mar 2, 2008 | 10:27 PM
Red2.4SS's Avatar
I know mine was slipping! I got that SPEC stg3+ from you guys and now its awesome! Even with the stock flywheel!
Now I need to dyno it again!
Weather can make a big difference too! If it was warmer and dryer on the first day it would give somewhat lower numbers.
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
SSLOW06
Oct 1, 2015 07:21 PM
Tupp
Sep 30, 2015 08:18 PM
