Cobalt SS ---> Ariel Atom build!
Old Apr 21, 2016 | 07:52 AM
mchism7's Avatar
Talking Cobalt SS ---> Ariel Atom build!
Hello!!!!
Do you know what an Ariel Atom is??!
Lets build one!
I purchased a 2006 cobalt SS, superchared, with 111k on it. a few days ago, I made some videos of the progress so far. I finally got the enigine out!
My Challenge to all you awesome Cobalt SS folk is your input on the car build with the engine and tranny etc, from the SS.
Here the link to the youtube videos..
https://www.youtube.com/watch?v=RkGG...ature=youtu.be (might still be loading)
Have fun!
Old Apr 21, 2016 | 09:17 AM
yellowsupercharged06's Avatar
what input do you want from us ??? You have the engine and trans from your donor car ....
We are all very aware of the aerial atom .... do you have an atom kit or something that your using ?
Old Apr 21, 2016 | 09:23 AM
Axelthered05's Avatar
you can sell most of the rest of the car to finance the rest of the build, the front rear bumper side skirts lips interior should all sell pretty quick if your ok with parting them
Old Apr 21, 2016 | 09:37 AM
mchism7's Avatar
Hi!
Well a couple things would be awesome to start with...Does anyone have a pdf manual? For wiring diagrams and such.
I will need to rewire it once I pull the wiring today.
Also, does anyone want any parts?
I have a carbon fiber hood if anyone wants it. Lights, windows, etc.
Thanks!
Mike
Also, how can I set up the stage 4 that I have been hearing about, lastly, anyone ever done an A/c and heating core delete?
Thanks!
Old Apr 21, 2016 | 09:48 AM
also one thing your going to want to do is pick up a copy of hp-tuners and if you keep all the wiring data systems you can tune the engine and turn off codes for systems you wont need like the evap system and such im guessing you want to retain the gauge cluster so hp tuners is your friend as it will also allow you to adjust fuel level data for use with either a different fuel level sensor or lower capacity tank with the cobalt electronics the ac delete is also an hp-tuners thing
Old Apr 21, 2016 | 09:51 AM
these are your friends
Classifieds - Cobalt SS Network
https://www.cobaltss.net/forums/part...-parts-274815/
Old Apr 21, 2016 | 10:07 AM
your going to have to take the fuse box apart, each wiring harness plugs into the bottom of it and can be disconnected without cutting. you just need to remove the bottom of the harness and unscrew the locking bolts
Old Apr 21, 2016 | 10:10 AM
id take the trunk if its wingless lol
Old Apr 21, 2016 | 11:37 AM
I wouldnt run rear brakes on the front, they have the ebrake mechanism built into the caliper. Maybe run two sets of fronts all around or get some ss/tc brembos for the front. Its not like youll be able to use the cobalt rear suspension for anything anyway
Old Apr 21, 2016 | 11:41 AM
I see you're in the Denver area, if you're wanting to sell some stuff off of it hit up the 5280Cobalts page on fb. I actually may know someone who would want the carbon fiber hood.
Old Apr 21, 2016 | 11:54 AM
mchism7's Avatar
Yes I want to part out everything but what I need for the engine tranny, and braking, and steering
Old Apr 21, 2016 | 11:58 AM
mchism7's Avatar
It has the wing on it
Old Apr 21, 2016 | 11:59 AM
mchism7's Avatar
True, ill pick up a set of front bearings, knucles, caliper, and disc assembly.
Thank you!
Old Apr 21, 2016 | 12:02 PM
mchism7's Avatar
I posted on Fb thanks!
Old Apr 21, 2016 | 12:19 PM
Throw a pic up there and a short description of what you're doing and then we'll share it from the 5280 side so more will see it and more locals will comment on the project.
Old Apr 21, 2016 | 12:21 PM
mchism7's Avatar
2006 yellow cobalt SS parting out
Here is the facebook ad
ALL body is in great shape, all windows except windshield is perfect. All lights in great shape.
Thank you so much!
Old Apr 24, 2016 | 09:28 PM
pcm pin out
Old Apr 24, 2016 | 10:37 PM
mchism7's Avatar
Thank u so much! This helps a lot!
SSxTc0825
Nov 14, 2020 02:05 PM
riceburner
Apr 12, 2016 09:19 AM
maliki778
Mar 30, 2016 01:25 PM
mikeluis92
Mar 30, 2016 11:52 AM
bigdogstokes16
Mar 29, 2016 01:52 PM
