Coming Soon - New Tires....
Well it's that time(even though it shouldn't be
) to get new tires. I have put about 16k on these pirellis being nice to them and they are finally out of tread basically. Next week perhaps I am going to place an order for new tires. Thinking of purchasing some nitto tires. My buddy/roomate had an 03 Cobra and used Nittos in the front and BF Drag Radials in the back. He said they handled like they are on rails before he got the BF drags.
Click Here
They are a touch bigger then the stock tires it's 225/45/R18 rather then 215/45/R18. Discount tire has confirmed these tires will fit my car. The other generation tires they have are too big to fit my car. Plus at $144 a crack they are cheaper then the $200 a tire Pirellis Discount is sporting.
Opinons welcome. I would like to see if someone else sells a decent tire besides BF Goodwrich. There tires are expensive! And Michelin is kinda crappy. Want something that will help launch good and stick good with reasonable treadlife without getting all season tires
Click Here
Well Discount checked out my tires I have right now (2nd opinon since the dealership said they were bald). They said they weren't bald like the dealership said
, in fact.. they still have half the tread life on them. I got them rotated today. Don't always trust what a dealership says. Kinda upset that I almost ordered new tires when I didn't need them yet.
Edit, taken from AAA Michigan website:
Measure tire tread with a depth gauge (available at most parts stores) or a small ruler that has 1/16" graduations. Although it is not as accurate, you also can check tread depth by placing a penny in the tread of the tire. Insert the penny upside-down (inserting President Lincoln's head into the tire's tread). If President Lincoln's entire head is showing, it is time to replace your tires.
Take measurements in three locations across the tire's tread: (1) outer edge, (2) center, and (3) inside edge. The more tread the tire has remaining, the higher the reading will be. Uneven readings indicate improper tire inflation or the need for a wheel alignment. At 3/32 of an inch, it is time to shop for new tires. At 2/32 (1/16) of an inch, the tread wear has reached its legal limit in most states.
your funny. I'm down the street from you basically.
By the way the 225/45/r18s should be ok, I know they usually recommend keeping the circumfrence (or diameter, either usually comes out close to the same) within 5% and that's a 4% difference.
I had my Nitto NT450's on my Sunfire for over 2 yrs and they still had half the tread left when I gave them to my brother.
I would recommend going w/ Toyo Proxy T1-S or the new T1-R. Wet traction is amazing.
At least those tires have a higher treadwear indicator than the Pirelli's. 16K miles on a set of tires is pretty bad. They don't make enough tires for this car. Where are our options. I would like to see something with a bit higher treadwear and perhaps an all season tire for this car.
all 110-120 horses? phew that's hot
hope you get your new car soon.
I'd go with 225/40/18s. 45 series might look funny because the sidewall will be bigger. It looks ok on a 215/45/18, but a 225/45/18 might not look as good. 225/40/18 is a popular size, so I'm sure you'll have lots of options to go with.
The nittos are great tires, and they have one of the biggest contact patches, but like someone said, they wear very quick
Originally Posted by love my SS
Honestly, if you're driving around corners pushing the extents of the Pirelli's traction, you are either on a race track or a reckless driver and need to get off the road. I don't think it's such a stupid idea to offer a marginally better treadlife tire when the sacrifice in traction would be unnoticable to most sane drivers.
You can still get very good traction and more than 16K miles out of other tires out there on the market. Hopefully BFGoodrich will start making some of them for the SS soon.
DANRICKARD
Oct 1, 2015 12:08 AM
