Commonly Used Forum Acronyms
Old 08-19-2012, 12:00 AM
Aleksey's Avatar
Lightbulb Commonly Used Forum Acronyms
Commonly Used Car Related Acronyms:
ABS - Anti-Lock Brakes
ABRS - Air Bag Restraint System
AC - Alternating Current
A/C - Air Conditioning
ADJ - Adjust or Adjustable
ADV - Advance
AFS - Airflow Sensor
A/F - Air/Fuel Ratio
AI - Air Injection
AIR - Air Injection Reactor
AIS - Air Injection System
ALT - Alternator or Altitude
ALDL - Assembly Line Data Link
Amp - Ampere
APS - Absolute Pressure Sensor
ASDM - Air Bag System Diagnostic Module
ASV - Air Suction Valve
A/T - Automatic Transmission
ATF - Automatic Transmission Fluid
ATS - Air Temperature Sensor
AWD - All Wheel Drive
AUX - Auxiliary
AVG - Average
BAC - By-Pass Air Control
BAP - Barometric Absolute Pressure Sensor
BARO - Barometric
BATT - Battery
BCM - Body Control Module
BHP - Brake Horsepower
BMAP - Barometric and Manifold Absolute Pressure Sensor
B/P - Backpressure
BPS - Barometric Pressure Sensor
BTU - British Thermal Unit
BVSV - Bimetallic Vacuum Switching Valve
C - Celsius
CAB - Control Arm Bushing
CAI - Cold Air Intake
CAT - Catalytic Converter
CB - Circuit Breaker
CC - Cubic Centimeter
CCW – Counterclockwise
CED – Crate Engine Depot
CID - Cubic Inch Displacement
CM - Centimeter
CMP - Camshaft Position Sensor
CO - Carbon Monoxide
CO2 - Carbon Dioxide
CPU - Central Processing Unit
CSSA - Cold Start Spark Advance
CSSH - Cold Start Spark Hold
CTS - Coolant Temperature Sensor
CTS - Catera Touring Sedan [Cadillac brand related]
CTVS - Choke Thermal Vacuum Switch
CVC - Constant Vacuum Control
CVR - Control Vacuum Regulator
CW - Clockwise
CYL - Cylinder
D/P - Downpipe
DB - Decibels
DC - Direct Current
DEFI - Digital Electronic Fuel Injection
DERM - Diagnostic Energy Reserve Module
DFI - Digital Fuel Injection
DFS - Deceleration Fuel Shutoff
DIAG - Diagnostic
DIC - Driver Information Center
DIST - Distribution
DLC - Data Link Connector
DOHC - Double Overhead Cam
DTC - Diagnostic Trouble Code
DOT - Department of Transportation
DRB-II - Diagnostic Readout Box
E85 - Ethanol Fuel Mixture 85% Ethanol + 15% Gasoline
EACV - Electronic Air Control Valve
EBCM - Electronic Brake Control Module
EBM - Electronic Body Module
ECA - Electronic Control Assembly
ECM - Engine Control Module
ECU - Electronic Control Unit
EFI - Electronic Fuel Injection
EGO - Exhaust Gas Oxygen Sensor
EGR - Exhaust Gas Recirculation
EGRPS - EGR Valve Position Sensor
EGRT - EGR Temperature
EI - Electronic Ignition
EMI - Electromagnetic Interference
EMR - Electronic Module Retard
EOS - Exhaust Oxygen Sensor
ESC - Electronic Stability Control
EVAP - Evaporative Emission System
EVIC - Electronic Vehicle Information Center
F - Fahrenheit
FI - Fuel Injection
FWD - Front-Wheel Drive
G85 - Limited Slip Differential Option for GM
GDI - Gasoline Direct Injection
GEN - Generation
GND or GRND - Ground
GPS - Global Positioning System
GVW - Gross Vehicle Weight
H20 - Water
H/D - Heavy Duty
H/E - Heat Exchanger
Hg - Mercury
HGT - Height
HLDT - Headlight
HO - High Output
HO2S - Heated Oxygen Sensor
HP - High Performance or Horsepower
HPT - HP Tuners
HTR - Heater
HZ - Hertz
IACV - Idle Air Control Valve
IAT - Intake Air Temperature
IATS - Intake Air Temperature Sensor
IC - Integrated Circuit
I/C - Intercooler
ICM - Ignition Control Module
ICS - Idle Control Solenoid
ID - Identification
IFI - Indirect Fuel Injection
IGN - Ignition
IN - Inches
INJ - Injector
ISC - Idle Speed Control
ISO - International Standards Organization
ITCS - Ignition Timing Control System
ITS - Idle Tracking Switch
IVSV - Idle Vacuum Switching Valve
KM/H - Kilometers Per Hour
KS - Knock Sensor
L61 - EcoTec 2.2L pre-2009 Engine
LAP - EcoTec 2.2L post-2009 Engine
LCD - Liquid Crystal Display
L/D - Light Duty
LE5 - EcoTec 2.4L Engine
LED - Light Emitting Diode
LHD - Left-Hand Drive
LNF - EcoTec 2.0L Turbocharged Engine
LSJ - EcoTec 2.0L Supercharged Engine
LSD - Limited-Slip Differential
LTFT - Long Term Fuel Trim
LWB - Long Wheel-Base
MA/MAF - Mass Air Flow
MAFS - Mass Air Flow Sensor
MAP - Manifold Absolute Pressure
MAT - Manifold Air Temperature
MFI - Multiport Fuel Injection
MIL - Malfunction Indicator Light
MPG - Miles Per Gallon
MPH - Miles Per Hour
MPI - Multi-Point (Fuel) Injection
MPV - Multi-Purpose Vehicle
NA - Not Available
N/A - Naturally Aspirated
NOx - Oxides of Nitrogen
NVRAM - Nonvolatile Random Access Memory
O2 - Oxygen
O2S - Oxygen Sensor
OBD - On-board Diagnostics
OBD I - On-board Diagnostics One
OBD II - On-board Diagnostics Two
OBD III - On-board Diagnostics Three
OC - Oxidation Catalyst
OD - Overdrive
O.D. - Outside Diameter
OE - Original Equipment
OEM - Original Equipment Manufacturer
OHC - Over Head Camshaft
OHV - Over Head Valve
O/S - Oversize
OS - Oxygen Sensor
OTTP - Over The Top Performance Company
P/N - Part Number
PCM - Powertrain Control Module
PCV - Positive Crankcase Ventilation
PECV - Power Enrichment Control Valve
PFI - Port Fuel Injection
PID - Parameter Identification
PIP - Profile ignition pick-up
PNP - Park Neutral Position Switch
PPM - Parts Per Million
PROM - Program Read Only Memory (chip)
P/S - Power Steering
PSI - Pounds Per Square Inch
PSP - Power Steering Pressure
PSPS - Power Steering Pressure Switch
PTC - Pending Trouble Code
RABS - Rear Anti-lock Brake System
RAC - Remote Accessory Controller
RAM - Random Access Memory
RCM - Restraint Control Module
REC - Receive
RECAL - Recalibrate, Recalibration
RECIRC - Recirculation
REF - Reference
RKE - Remote Keyless Entry
ROM - Read Only Memory
RPD – Reprogrammable Performance Display
RPM - Revolutions Per Minute
RSC - Roll Stability Control
RWD - Rear Wheel Drive
S/C - Supercharged
SEFI - Sequential Electronic Fuel Injection
SES - Service Engine Soon (light)
SFI - Sequential (Port) Fuel Injection
SIL - Shift Indicator Light
SIR - Supplemental Inflatable Restraint
SIPS - Side Impact Protection System
SOHC - Single Overhead Cam
SPFI - Sequential Port Fuel Injection
SRI - Short Ram Intake
SRS- Supplemental Restraint System
SRT - System Readiness Test
S.R.T. - Street & Racing Technology
STFT - Short Term Fuel Trim
STS - Short Throw Shifter
TACH - Tachometer
TB - Throttle Body
TBI - Throttle Body Injection
T/C - Turbocharged
TCC - Torque Converter Clutch
TCM - Transmission or Transaxle Control Module
TCS - Traction control solenoid
TD - Turbo Diesel
TDI - Turbo Direct Injection (A turbo charged direct injected diesel engine)
TPS - Throttle Position Sensor/Switch
TPT - Throttle Position Transducer
TTR – Turbo Tech Racing Company
TVS - Thermal Vacuum Switch
TWM - TWM Performance Company
VAC - Vacuum
VIN - Vehicle Identification Number
VM - Vacuum Modulator
VOLT - Voltage
VSS - Vehicle Speed Sensor
VSV - Vacuum Switching Valve
VTEC - Variable Timing Electronic Control
VVC - Variable Valve Control
VVT - Variable Valve Timing
WOT - Wide Open Throttle
ZZP – ZZ Performance Company
Other Commonly Used Forum Acronyms:
FS - For Sale
GLWS - Good Luck With Sale
IIRC - If I Recall Correctly
IMO/IMHO - In My 'Honest' Opinion
TTT - To The Top
QFT - Quoted For Truth
WTB - Want To Buy
Old 08-19-2012, 12:12 AM
1LowLS's Avatar
Sorry but CTS is for Catera Touring Sedan by Cadillac
Old 08-19-2012, 12:16 AM
Aleksey's Avatar
Got it
Old 08-19-2012, 12:33 AM
Ceej's Avatar
You forgot VTEC
Old 08-19-2012, 12:34 AM
1LowLS's Avatar
Variable Timing Electronic Control.
Old 08-19-2012, 12:37 AM
Ceej's Avatar
vtec - whum bummm bummm bahhhhhhh
Old 08-19-2012, 12:42 AM
AWD > FWD
TommyP's Avatar
Very nice! Thread stuck
Old 08-19-2012, 12:45 AM
Aleksey's Avatar
Added the almighty vtak
Old 08-19-2012, 12:48 AM
sjc0013 Licks windows
reduf99's Avatar
Call me a newb but whats iirc
Old 08-19-2012, 01:10 AM
Ceej's Avatar
If I remember correctly
Old 08-19-2012, 01:21 AM
Cobalt_Daddy's Avatar
QFT ^^^^ lol
(quote for truth)
Old 08-19-2012, 01:34 AM
Aleksey's Avatar
Added IIRC and IMO/IMHO
Old 08-19-2012, 11:16 AM
dobsongeorge's Avatar
Originally Posted by Aleksey
2010 LNF: Pedders, OTTP Rear S/B, Injen H/S, ZZP I/C, K&N SRI, ZZP DP, OTTP Stg2 T/M, Tint 30/15, MPx Shorty
Check out your personal car description. S/B, H/S, I/C, SRI, and T/M are all not listed.
Unless these wouldn't be considered common
Maybe add CAI as well - cold air intake
Good thread though. Free bump
Old 08-19-2012, 11:56 PM
Aleksey's Avatar
**** I made up, I honestly forget half of the time what they mean blame the sig maximum character allowance.
Added: D/P, CAI, SRI, H/E, I/C
Old 05-18-2013, 12:59 AM
Lala55's Avatar
hi Aleksey!
Thanks for sharing.
Old 08-02-2014, 08:50 PM
xsithx's Avatar
#cobatlanguage
Old 08-02-2014, 08:54 PM
Kahless's Avatar
PIITB
put it in the
boot.
and cts stands for compact touring sedan. caddy didnt want anyone thinking of the ***** catera when they made the cts. that dude was a tard.
Old 03-20-2016, 07:27 PM
Superslowbaltt's Avatar
What's gsm1
What's gsm1
Old 03-20-2016, 09:52 PM
General motors stage one upgrade for the lnf cobalt. It sa factory installed modification which includes a 3bar map sensor and a tune to produce more power
Old 03-20-2016, 09:57 PM
ATOMbomb's Avatar
Very helpful actually. Lol
Old 03-20-2016, 10:07 PM
So many threads buried and actually pretty helpful
riceburner
10-02-2015 05:47 PM
MrInsanityWolf
09-29-2015 04:54 PM
yellow dragon
09-28-2015 09:49 PM
09-26-2015 06:44 PM
Quick Reply: Commonly Used Forum Acronyms
