Confirm before I buy
Old May 9, 2012 | 12:54 PM
insylem's Avatar
Hello,
Before I click the Spend 1000 dollars button....
I want to make sure I'm buying all the right stuff...
88958710 Upgraded Steering Knuckle
88958711 Upgraded Steering Knuckle
19212712 GMPP Clutch
I dont really see a way to confirm these part numbers.
Anything ealse I should get?
Slave Cylinder? Clutch Pipe?
Old May 9, 2012 | 12:56 PM
kdub1492's Avatar
Tranny Fluid
Old May 9, 2012 | 01:07 PM
09BlueBaltSS's Avatar
If youre doing the clutch you will need
tranny fluid
clutch pipe
flywheel bolts(if resurfacing)
flywheel and bolts(if replacing with new flywheel)
Old May 9, 2012 | 01:11 PM
insylem's Avatar
tranny fluid
clutch pipe
I take it those don't come with the normal clutch?
I get clutch pipe, but why the tranny fluid?
Old May 9, 2012 | 01:18 PM
Pulling the axles?
The clutch kit comes with pressure plate, disc, slave and pressure plate bolts
Old May 9, 2012 | 01:24 PM
Sir_Hiro's Avatar
You will lose tranny fluid as you replace the clutch.. Plus its good to have around..
Old May 9, 2012 | 01:27 PM
kdub1492's Avatar
you can get the redline mt-90 ****...hell of a lot cheaper then getting the stuff from crateenginedepot
Old May 9, 2012 | 01:35 PM
Maven's Avatar
Skip the knuckles.
Old May 9, 2012 | 01:49 PM
Superbalt06's Avatar
I use redline in all my cars. I would definitely do the slave cylinder and the clutch pipe while you're in there.
Old May 9, 2012 | 02:40 PM
Maven's Avatar
I really like Redline stuff too, but LNF gear oil is abiut the best there is for the F35
Old May 9, 2012 | 02:54 PM
jmfselu's Avatar
just changed my lnf tranny fluid at 70,000 miles and wow what a difference.
dennis69
Oct 20, 2015 04:49 PM
patooyee
Oct 15, 2015 05:11 PM
OrangeCoba
Oct 1, 2015 10:00 PM
Iceberg
Sep 29, 2015 12:33 PM
Iceberg
Sep 28, 2015 01:31 PM
