No power to blower motor
Old May 8, 2012 | 11:26 PM
dixiebandit69's Avatar
I'm working on an '06 Cobalt, and there is no power getting to the HVAC blower motor. The fuse and relay are both good, but there is no power coming from the #30 terminal for the relay (what a strange place to put the fuse block!).
I'm not really familiar with these cars, so I was hoping that someone could tell me what else I need to check since I don't have a factory service manual.
Old May 8, 2012 | 11:32 PM
BankerBalt's Avatar
could be a bad switch on your console... been known to happen on gm cars
Old May 8, 2012 | 11:36 PM
nhanson's Avatar
It doesnt work on any speed?
Old May 9, 2012 | 02:23 PM
Nope. The customer said that initially it wouldn't work on any speed except high, then it stopped working altogether.
Oh, I forgot to mention that the blower motor resistor is new.
Old May 10, 2012 | 06:00 PM
Malaclypse's Avatar
(Stupid question) Did you check the fuse under the hood?
If the fuse is okay poke around behind the A/C control head and see if there's any obvious problem.
Old May 10, 2012 | 08:42 PM
SaberD's Avatar
you may want to re-check to make sure it was installed correctly or didn't blow out again. there could be a short causing it to blow out. a double check can work wonders.
Old May 10, 2012 | 09:46 PM
Maven's Avatar
Disconnect the blower motor, and use a test light attached to power on one end and attach the other end to the orange wire in position A of the blower connector. The light should come on at varying brilliance based on what speed you select, if it doesnt come on at all then youve likely got a bad ground or control head, if it works normally youve got a power side issue.
Do those checks and then youll be down to, BCM, fuse block or wiring repair.
Solaris99
28
Mar 15, 2017 01:22 PM
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
ThoR294
Oct 4, 2015 08:44 PM
jimbofug007
Oct 2, 2015 12:06 PM
Stuff
Oct 1, 2015 05:47 PM
