No power to blower motor
I'm working on an '06 Cobalt, and there is no power getting to the HVAC blower motor. The fuse and relay are both good, but there is no power coming from the #30 terminal for the relay (what a strange place to put the fuse block!).
I'm not really familiar with these cars, so I was hoping that someone could tell me what else I need to check since I don't have a factory service manual.
Disconnect the blower motor, and use a test light attached to power on one end and attach the other end to the orange wire in position A of the blower connector. The light should come on at varying brilliance based on what speed you select, if it doesnt come on at all then youve likely got a bad ground or control head, if it works normally youve got a power side issue.
Do those checks and then youll be down to, BCM, fuse block or wiring repair.
ThoR294
Oct 4, 2015 08:44 PM
