Coolant overheated tonight..
So tonight my coolant suddenly skyrocketed, and boiled over and started spilling out everywhere.. I was about 50k from my house and had just been on the highway, and was sitting in stop and go traffic for about 30 minutes after.
The temps got up to 200C, it really shocked me that it went through the roof like that. A few hours later I checked it and it wasn't leaking anymore, and the coolant level was a bit low but it still had enough to run. I drove it all the way home and it never went over 90C.
Was this just a result of me sitting in stop and go traffic and being on the highway? Or possibly the IC pump stalled? Or something else?
I can't see anything outside right now and the dealership (it's still under warranty) isn't open till monday, so some suggestions on what to look for would be nice.
Also, how do I go about topping it up? Is it 50/50 dexcool/water, or just straight dexcool I have to add? I guess I can check the manual but I'm tired as hell and I can't be bothered until I can actually see outside.
Thanks for any help guys!
i doubt the motor actualy got that hot. what could have happened is it got a bit hot and puked a bit of coolant out and an air pocket formed around the tempo sensor (can happen, the sensor is rather high on the lsj), and that pocket will just heat right up even though the coolant is still in a more normal range.
I would advise a compression test just to be safe, but if you are under warranty, take it in and let the dealer worry about it.
Yea I questioned whether it really got that hot, Sharkey's explanation sounds truthful.
Well the dealership isn't open, and I work Mon-Fri so probably won't be able to take it in till next Sat.. luckily I drive a company car to work.
How do I go about topping it up? 50/50 Water/Dex or just straight Dexcool?
Also, if I can't see any evidence of leaking do you guys think I'm safe to drive it a few km's?
How can I get the fans to come on manually? The ambient temps outside are like 5C.. it's not very hot out.
On a side note I topped up my coolant today, it doesn't seem to be leaking anywhere, and my temps are still staying below 90C. On the way home (25 min drive) the highest reading I had was 86C.
Car is running like nothing ever happened.
Nothing really is going to raise the i/c coolant temp that high. Bunk pump maybe 200f depending on your run time.
Top it off with either 50/50 any coolant or dilute that with water if you want cooler i/c temps and aren't afraid of rusting and/or freezing.
It was my engine coolant, not the I/C system. I topped it off with 50/50, but as the others have said I doubt it really hit 203C. My car would not be running the way it is (if at all) if it had reached that temp.
I'm gonna call the dealership tomorrow and see what they suggest, and I'm going to run the a/c and defroster and see if I can see the rad fans running. I doubt they'd be faulty though otherwise I wouldn't have been able to idle at stoplights with my temps staying under 90C. I had it sitting in the driveway for 10 minutes running the coolant through the system and temps reached 77, then dropped down to 72 and stayed there.
