Diff. between SS/SC 05-06
Originally Posted by Wpns421
What is the difference between the Cobalt SS/SC 05 and 06 ??
GM should be upgrade ??
Tanks !!
Tanks !!
Originally Posted by p7x
1 year
No differences cept in Canada for 2006 you can get the LSD and Recaro package and the car in Ultra silver.
Originally Posted by 2006ArrivalBlueSS
You cannot get a silver 2.0L in Canada at this time, just the 2.4L is available in that colour...I would have chosen Silver if it was available but I'm just as happy with my very limited 2006 ArrivalBlue 2.0L...not too many of these on Canadian roads which is what I like!!!
As for the rare car same here
Originally Posted by sneaky
Talks of different PCM's but other then that, it's all the same minus the recalls on some stuff. no difference.
The only major improvement I am aware of in the 06 models is an upgrade to the Theft Detterant system from problematic GM Passlock (used in 05) to the more reliable and secure PassKey 3+ (adds a new module and puts a "transponder" in your key)
A few other choice tidbits on what changed for 2006 can be found here:
http://media.gm.com/us/chevrolet/en/...index.html#new
HTH
WOT
Originally Posted by codyss
Hmmm, I read on that link that the SS has a 22mm rear sway bar?
Three suspension settings are available:
FE1 suspension – standard on LS, LT and LTZ models, it provides a smooth ride and includes a 19-mm front stabilizer bar and a 16-mm rear stabilizer bar
FE3 suspension – standard on SS models, it delivers a firmer, more direct ride and includes 22-mm front and rear stabilizer bars, four-wheel disc brakes, monotube shocks and 17-inch wheels and performance tires
FE5 suspension – standard on the SS Supercharged, it was developed on the racetrack to deliver sports car levels of handling and grip; 24-mm front stabilizer bar and 22-mm rear stabilizer bar, higher-rate springs and bushings, four-wheel disc brakes, monotube shocks and 18-inch forged aluminum wheels with complementing performance tires
I'll put a mic on them next week
WOT
BTW> You can access more Cobalt info from here
Originally Posted by WopOnTour
There's no difference in the PCMs- SAME service part number!
HTH
WOT
HTH
WOT
see here
According to that site you have the gearing is all different between the SS/SC and the standard trans.
Old News
The Chevrolet web-site has been noted as being INCORRECT since it's inception
The ratios used in the Getrag F23 used with the NA engines have ALWAYS been different from the FGP F35 used in the Superharged engines.
WOT
WOT
So where is the rear sway bar hiding then?
Inside the torsen beam?
In the first magazine road tests it is mentioned that GM stated the rear suspension didn't need a rear sway bar so one was not used.
Look straight up inside your A-beam and you'll see the sway bar. It's welded to the rear trailing arms at each end.
Poo Poo to that mag
WOT
That was chevy high performance and they had a preproduction model. It had an armrest and a grille that was a snap in from the outside like the pursuit ours comes in from the back. If you look at the pics in the magazine you will see that the chasis they have has the stabilizer bar in the front bolted to the control arm ours has some sort of link that attaches it to the struts like the beretta gtz had.
satisfied
Oct 19, 2015 12:35 AM
