Different Oils on a dyno.
Old Sep 30, 2007 | 11:57 AM
Element2.4's Avatar
Here is some info I found from a shop thats close to me. I have met these guys and would believe the info is correct. They dynoed many different performance oils to see what the difference is. Here is the link to there forum.
http://my.prostreetonline.com/t2540.htm
Old Sep 30, 2007 | 12:06 PM
USMCFieldMP's Avatar
Rattlesnake Race Shop
Nice! That's some good stuff.
Old Sep 30, 2007 | 12:08 PM
Element2.4's Avatar
Ya its a lot of good info. I run royal purple in my car.
Old Sep 30, 2007 | 12:09 PM
I run Amsoil... and enjoy it. Looks like I need to switch though!
Old Sep 30, 2007 | 12:16 PM
06blackg85ss's Avatar
very nice... I just switched out to royal purple myself for the turbo setup
Old Sep 30, 2007 | 12:18 PM
proZak's Avatar
that was a good write up!!! I liked reading how much people know just about oil... and I didnt hear them say... oil doesn't break down... its the detergent that cleans your engine that breaks down(oil additives)
Old Sep 30, 2007 | 12:21 PM
anthonyS88's Avatar
+ rep already added for it on the other thread where it was posted
this was a great write up i just wish they showed what the red-line oil did
Last edited by anthonyS88; Sep 30, 2007 at 12:21 PM. Reason: Automerged Doublepost
Old Sep 30, 2007 | 12:27 PM
Dead Zen's Avatar
wow. royal purple is worth the $$$$$
Old Sep 30, 2007 | 12:28 PM
anthonyS88's Avatar
im about to go buy 7 quarts and a filter and change my oil tmr
Old Sep 30, 2007 | 12:29 PM
D4u2s0t's Avatar
nice find! everyone debates about these oils, nice to actually see some results.
Old Sep 30, 2007 | 12:31 PM
Element2.4's Avatar
It said they couldn't show the results on the redline because they had some "legal" issues when doing the tests
Dead Zen's Avatar
x3,000,000
Old Sep 30, 2007 | 12:33 PM
anthonyS88's Avatar
**** legal issues
Old Sep 30, 2007 | 12:34 PM
JPizzle's Avatar
Sooo... It sounds like Royal Purple gains more power than the other competitors...
Old Sep 30, 2007 | 12:37 PM
D4u2s0t's Avatar
i guess they didn't do so well in the tests
Old Sep 30, 2007 | 12:39 PM
Old Man's Avatar
It doesn't state that nor prove that.
If you read some decent summations done after the testing, the residual oil left from the previous test could in fact make Royal Purple look better.
Nice test, nice attempt, but sill way to many variables are still on the table.
Old Sep 30, 2007 | 12:40 PM
Element2.4's Avatar
Ya but its still better then just guessing out the ass.
Old Sep 30, 2007 | 12:43 PM
D4u2s0t's Avatar
isn't that why they did runs in between that didn't affect the score, to get rid of the residual oil? and why didn't residual oil help out the other one's that much? if it helps one, it would be safe to assume that i t would help them all, no? so in that case, ALL of them would be higher than normal.
Old Sep 30, 2007 | 12:46 PM
Old Man's Avatar
Not by much!!!
The tester points on a number of facts in his summation to say he knows his test is not accurate, but better than the ass dyno.
Another fact I know to be true , if you run a car on a dyno on and off again all day long without changing ANYTHING and even controlling the variables of intake temps, motor temps, things along that nature as the day progresses dyno numbers are always up, in fact rising each test.
You know why????
Tires begin to heat and conform to the drums. Better contact. better numbers???
Old Sep 30, 2007 | 12:51 PM
D4u2s0t's Avatar
Not by much!!!
You know why????
he also said that they controlled some of the variables between tests, SPECIFICALLY temps.
Old Sep 30, 2007 | 01:20 PM
Old Man's Avatar
But then again he goes and says there were different temps in effect and shows that in print.
Thats not controlling when a variable shows.
You look at a good engine dyno, its in a room where intake temp, humidity etc etc etc DO NOT WAVER from run to run. Thats controlled!!
DarrenGC
Dec 24, 2021 01:55 PM
717ssbalt
Oct 2, 2015 04:01 PM
importkiller
Sep 30, 2015 07:18 PM
dennis69
Sep 28, 2015 02:16 PM
