DIY Transmission Mounts A Success!
I filled the hollow areas in the two trans mounts with an epoxy used for fiberglass patching. And wow...wheel hop?? GONE!! It took a total of 3 hours due to fact that the epoxy had to cure. But all in all I only spent $75, and still have my stock mounts. The vibes are kinda crazy when I let out the clutch...but the benefits are so worth it! The car feels totally different, and I love it!!
Shifting is great. No wheel hop is great.
Once you're in 2nd you hardly even notice the vibes...its just in 1st when you're letting out the clutch that the vibes are intense...
I'm hoping it will hold up...but if it doesnt thats fine. The cracked pieces will probably just fall out leaving the stock rubber. I'll be checking on it once a week just to make sure...I wanted to try something different. I still have my stock mounts I can put back on...
