Drivers side Door Handle
Old Jun 27, 2005 | 01:05 AM
3fo893013L's Avatar
Maybe it's just me but since I've purchased this car in april, the drivers side door handle sticks all the fricking time, I ask the dealership to lube it and they do but it continues to get stuck about a week later.
It's funny. The handle will come out all the way but not go back in with giving it some force. Shouldn't be necessary. Sometimes I will catch myself not looking to see if the handle goes in all the way, get in the car and close the door only to find out it won't close because the handle it still in the open postion.
Next oil change I am going to make them take the door handle assembly apart and lube that thing so good that it will be opening like butter when done.
Old Jun 27, 2005 | 02:06 AM
PenguinPIE's Avatar
isnt that dangerous when the door is closed and the handle is still at the open position?.....hmm...definetly not rite
Old Jun 27, 2005 | 02:08 AM
bredick's Avatar
I find this rather ammusing, considdering my '92 130,000m Cavalier has the same problem, but now I have a 2006 Cobalt SS/SC on order, maybe this problem is destined to haunt me for the rest of my life?
God I hope not. GM has a history of bad door handle design, my cavi for instance, uses a rod connected to the handle to operate the latch by PUSHING rather than pulling. A couple weeks ago it got snagged on my doorframe and bent, I couldn't get into my car, who would make a 3/16" x 8" rod push rather than pull? sure it would take an extra linkage but come on.
Old Jun 27, 2005 | 09:43 AM
Project Freeze's Avatar
the door handles on the cobalt are somewhat fragile you might have pulled it too hard once or twice this could be the reason why...this girl i know has the same handles on her door on her mazda6 and she almost ripped one off one time when she pulled on it...here is a trick if you do not already know, try putting your thumb over the key hole while pulling on the handle, it helps......
Old Jun 27, 2005 | 11:53 AM
3fo893013L's Avatar
The problem is I am not forcing it to open though, only closing it. *Door Handles*
Old Jun 27, 2005 | 01:07 PM
you should definately have that handle replace
Solaris99
28
Mar 15, 2017 01:22 PM
biniecki
Oct 25, 2015 02:23 PM
Jimmy Beilfuss
Oct 5, 2015 04:18 AM
Tupp
Sep 30, 2015 08:18 PM
Extremespeed
Sep 29, 2015 04:34 AM
