easiest way to plug wing bolt holes
easiest way to plug wing bolt holes..plain and simple i wanna take my wing off....any help or advice...besides plastering them up and re painting your trunk??
One cheap and very effective way to plug holes is take some clear silicone and mix into it some paint from your touchup can......then fill the holes with a glob of the silicone and let it dry......you can then take a razor blade and shave it down even with the surface.....just be sure to spread the silicone around on the inside of the hole so that it stays in place.....dont shave the silicone on the inside of the trunk.......not guarenteed to be perfect but looks decent without spendind a **** load of money welding and re-painting.
