Easy way to dynamat your firewall?
Title says it all... just installed an Ingalls and I'm getting mad vibes and engine noise (set at 12mm). Any easy way of getting access to layer some dynamat on? Do it from the engine bay side or pull the carpeting back in the cabin and attack it there? Will adding some to the struts help any?
Should I adjust the Ingalls any or add some dynamat to the brackets (i could hide it on the inside of the 2 so you couldn't see it). Thanks in advance
instead of spending your money on dynomat,go to home depot,they have this sound proofing stuff(also fire resistant) its for homes and comes in rolls that happens to be sticky on one side also,it is also much cheaper than dynomat.
