Engine Corrosion
Old May 2, 2011 | 10:47 PM
SherlockHolmeSS's Avatar
Engine Corrosion
Hey everyone. I'm going to be doing some paint work under the hood within the next couple weeks, but there is a ton of corrosion (due to NY winter salt). Has anyone had this? And if so how did you go about removing it? Thanks in advance!
Old May 2, 2011 | 10:48 PM
DiabeticKripple's Avatar
i just sprayed my engine bay down. looks good now
Old May 2, 2011 | 10:55 PM
^^ yeah I've tried spraying it and it didn't do anything. The motor mount and the engine has got corrosion all up on it
Old May 2, 2011 | 10:58 PM
probably just gotta get new parts
Old May 2, 2011 | 10:59 PM
^I'm really hoping that's not the case. Some people are saying WD-40 might do the trick
Old May 2, 2011 | 11:00 PM
TommyP's Avatar
AWD > FWD
go to work with some sand paper wetsanding
Old May 3, 2011 | 01:35 AM
Martel18SS's Avatar
Buff it.
Old May 3, 2011 | 12:13 PM
Phil424's Avatar
So your telling this guy if any part on the car has rust build up, but the part itself is fine, he needs to get new parts? I guess he'll be replacing almost every part of the suspension then.
Old May 3, 2011 | 12:48 PM
1AJeremyD's Avatar
POR-15 it. It prevents rust and works great. I just used not even half a can on my brake calipers and they look awesome as well as the rust on my winter beater explorer
Old May 3, 2011 | 09:12 PM
thanks guys, I'll try some of this stuff out. Should I just put a jack under the motor to take off a motor mount?
Old May 3, 2011 | 09:16 PM
ok take it to the extreme buddy. when i first thought of corrosion, i thought like really bad, didnt think that a little sandpaper would get rid of it.
Old May 5, 2011 | 01:11 PM
K-Train04RL's Avatar
emery cloth, and some sandpaper should have no problem taking off surface rust. then clear coat it with some rust check to prevent new corrosion.
HEATON
Oct 16, 2015 07:21 PM
ernnyyes
Oct 2, 2015 05:16 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
DocSvensk
Sep 27, 2015 02:24 PM
