Front Bumper Crakced
Old Dec 3, 2007 | 08:59 PM
bmrt13's Avatar
Is there anyway to fix it without buying a new one? Its a small crack at the bottom of the driver side
Old Dec 3, 2007 | 09:05 PM
Stubri51's Avatar
You could use a plastic welder which is like a soldering iron and melt it back together using the appropriate filler rod. Or if you have access to it 3M makes an entire line of plastic repair parts which aren't hard to use but they are expensive to get everything you need especially if you just need it for one job. Your local body shop should be able to fix it. Hopefully that helped you out a little.
Old Dec 3, 2007 | 09:43 PM
Sharkey's Avatar
id try to get the plastic weld stuff, should hold better. ive used the urethane repair kits before, they work ok till you bump something.
Old Dec 3, 2007 | 10:24 PM
bmrt13's Avatar
alright thanks, some idiot must have backed into me or something cuase i know i didnt hit anything and im the only one who drives it.
Old Dec 3, 2007 | 10:34 PM
ItalianJoe1's Avatar
Try some Epoxo 88, its some serious stuff, bonds damn near anything with 1500psi force.
SSLOW06
Oct 1, 2015 07:21 PM
Tupp
Sep 30, 2015 08:18 PM
Delta coupe
Sep 30, 2015 08:11 AM
n20saturn
Sep 30, 2015 12:26 AM
grampss
Sep 27, 2015 08:51 PM
