Front Bumper Crakced
You could use a plastic welder which is like a soldering iron and melt it back together using the appropriate filler rod. Or if you have access to it 3M makes an entire line of plastic repair parts which aren't hard to use but they are expensive to get everything you need especially if you just need it for one job. Your local body shop should be able to fix it. Hopefully that helped you out a little.
Delta coupe
Sep 30, 2015 08:11 AM
n20saturn
Sep 30, 2015 12:26 AM
