Gas?
Old Jul 5, 2006 | 02:37 PM
roccobladr's Avatar
Gas?
what kind of gas do you guys use?
i have a 2.4SS and the manual says i can use the 87 or whatever, but premium can be used for better performance. i only have put gas in it once and i just put in the regular.
also, i dunno if my dealer was just bullshittin me, but he told me that my 06 can use the E85 or wahtever **** that they use out in the midwest. is that true?
Old Jul 5, 2006 | 02:57 PM
g5mike's Avatar
I always use 94 octane,but sometimes use 91 octane. This is a high output motor,if you use 87-89 you will not get the same performance and might experience some engine knocks
Old Jul 5, 2006 | 02:59 PM
roccobladr's Avatar
ugh premium around here is at least 3.50 a gallon. is it ok to use premium sometimes? or should i just stick with one grade?
Old Jul 5, 2006 | 03:00 PM
1stbluSS's Avatar
short answer. You can use whatever gas you want.
Old Jul 5, 2006 | 03:03 PM
D4u2s0t's Avatar
use the lowest octane that won't product engine knock... any more than that and you're doing 2 things:
1) Wasting your money
2) Hurting your performance
Incognito's Avatar
is it vital to use the premium on the SS/SC ?
dealer told me "its all it will run on", but I read that some people put the regular fuel in with no problems ?
Old Jul 5, 2006 | 03:05 PM
1stbluSS's Avatar
it will run on lower than premium. The computer sees the lower octane and takes away some ponies.
Old Jul 5, 2006 | 03:10 PM
roccobladr's Avatar
how bout that E85 ****?
Old Jul 5, 2006 | 03:11 PM
1stbluSS's Avatar
how about rocket fuel ? E85 I beleive needs to have a different set of 02 sensors.
Old Jul 5, 2006 | 03:14 PM
roccobladr's Avatar
is E85 the corn ****? lol i forget what its called. its like what they are using out in the midwest or whatever.
Old Jul 5, 2006 | 03:22 PM
Tomtwtwtw's Avatar
http://www.gm.com/company/onlygm/energy_flexfuel.html#
If your car's not there (and it isn't), then don't use E85.
Old Jul 5, 2006 | 03:26 PM
RaineMan's Avatar
None of the Cobalts will run the E85...
You can use whatever gas you want to in the 2.4... but premium is best for performance.
Old Jul 5, 2006 | 03:27 PM
06G5GT's Avatar
E85 will destroy your car. The flex fuel vehicles are modified because ethanol is highly corrosive.
Old Jul 5, 2006 | 03:28 PM
roccobladr's Avatar
aw ok. i didnt really plan on using it anyway. just goes to show how much of a douche my dealer is. i should tell him i put some in and my car blew up or something lol.
Old Jul 5, 2006 | 04:38 PM
chipmonk212121's Avatar
If you have the stage 2 you probably need 93 octane. The retuned PCM usually requires a higher octane. If the manual says 87 is fine.... use 87. If it says premium only, then use premium. Your computer is tuned for a certain octane. My 200hp 3.8 didnt need 93 octane till i got my computer reprogrammed. the only way you will know for sure is either A) experimenting with mileage and testing performance (ex. take it to the track) with each fuel. or B) scanning it to find out if there is spark knock.
Old Jul 5, 2006 | 04:49 PM
05BlackCobaltSS's Avatar
yea, The E85 will eat your engine alive! DO NOT USE THE E85!!! But i always use Shell V-Power, but use whatever you want. That is, until you start to get knock, then move up a few Octane Levels.
Old Jul 5, 2006 | 04:53 PM
1stbluSS's Avatar
bwahahahahahaaha
HE SAID CORN **** ! I JUST HAD THAT AFTER LUNCH LOOKED DOWN AND THERE WAS SOME CORN !
Old Jul 5, 2006 | 05:28 PM
Originally Posted by 1stbluSS
bwahahahahahaaha
Old Jul 5, 2006 | 05:33 PM
plyboy-illest's Avatar
nothign but premium here!
Old Jul 5, 2006 | 05:46 PM
budman128's Avatar
All we got here is 91 or 87 so I run 91
Old Jul 5, 2006 | 11:54 PM
css9450's Avatar
Ya around here there is no 93 or 94...
Old Jul 6, 2006 | 10:29 PM
The owners manual says to run 87 octane in the 2.2 and 2.4 and to run 91+ in the 2.0 SC to avoid spark knock and power loss.
I live in Illinois and everywhere I go there is 93 octane.
Old Jul 6, 2006 | 11:49 PM
TheCaptain's Avatar
I run Shell's V-Power 91 in my '91 Caprice Classic 5.0L. It bumps the mileage up a bit and really helps turn tires...
Bet that helped a lot!
RaginChopsuey
Oct 27, 2015 01:27 PM
biniecki
Oct 25, 2015 02:23 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
roth
Sep 26, 2015 12:16 PM
