Gas grade
the octane rating of fuel is the fuels resistance to igniting. a higher octane fuel is harder to ignite. with low grade fuels in a boosted engine you can get detonaton because the fuel is to easy to ignite and it end up igniting from heat in the combustion chamber, not from the spark itself. this is why premium fuel must be run in our cars, it resists detonation better. now if you are not seeing any knock retard with your current tune, there is no reason to go with higher octane fuel, as the engine has a harder time burning it. because of this you could lose power.
about the only time to run 100 octane in our cars is a) tune for it, or b) running a stage 3 pcm. if you do run it, make sure its unleaded, as leaded fuel will foul your o2 sensors and clog the cat.
roth
Sep 26, 2015 12:16 PM
