General question.
Old Feb 3, 2007 | 06:13 AM
redlineblueline's Avatar
yes theres just something about animation/technical drawings that aid my understanding I could have something in my hand or be able to touch it and take it apart and I wont understand it as well as if i have a techinical drawing
Old Feb 3, 2007 | 06:14 AM
NJHK's Avatar
yeah, same here.
Old Feb 3, 2007 | 06:17 AM
i love the butt secks all star
Old Feb 3, 2007 | 06:20 AM
NJHK's Avatar
And I love you too
Old Feb 3, 2007 | 06:23 AM
total gheyness
Old Feb 3, 2007 | 08:22 AM
aj_92rs's Avatar
Ecotec engines use sequential fire injection. Each injector is opened only when it's dedicated cylinder requires fuel.
I only mention this because MPFI is a generic term. Some MPFI systems used a batch fire setup that would open a group of injectors at once just to deliver fuel to one bank of cylinders.
SEFI is far superior.
Old Feb 3, 2007 | 11:48 AM
Halfcent's Avatar
I'm old school
Every Ecotec since the begining has had the same injector setup until the LNF (later). The injectors are mounted into the cylinder head and spray directly against the face of the intake valve.
(pic here later, I promise)
The heat of the intake valve helps to further atomize the fuel and promotes mixing before entering the combustions chamber. The injector does NOT fire only when the intake valve is open. An injector operating at 80% duty cycle is open for 576 degrees of crankshaft rotation. A typical intake valve is open for 210 degrees. The fuel simply mixes inside the intake port until the cylinder draws it in.
The LNF's direct injection is VERY different. First, as already discussed, it fires directly into the combustion chamber.
This injector fires during the intake stroke at a much higher flow rate then a typical injector. It has to deliver as much fuel in less time. Mixing occurs directly inside the chamber. One advantage of this is you can meter fuel into the chamber whether or not the intake valve is open.
Additionally, the injector will actually fire during the exhaust stroke when the engine is cold to warm the engine up faster for better emissions control.
Old Feb 3, 2007 | 12:17 PM
hectanooga's Avatar
Halfcent, What does LNF stand for? I've been racking my brain, but I don't think I have ever seen that acronym before.
Old Feb 3, 2007 | 02:51 PM
Halfcent's Avatar
I'm old school
It is not an acronym. Its the GM product code for the engine. There are a lot of Ecotec engines.
L61-The original 2.2L all aluminum Ecotec, created from the Saab design.
L42-The natural gas version of the L61
LSJ-The supercharged 2.0L
LE5-The 2.4L VVT engine
LNF-The 2.0L turbo
LK9-The Saab iron block turbo
There are others as well. Some are discontinued. I always talk in these terms to eliminate confusion between models.
In the current production models, they all share the same basic block design. They are in fact interchangable except for the LE5. It's kind of the bastard child. The only real difference between them all are their rotating asseblies (also interchangeable) and their heads (limited interchangability)
Sean Cummings
Jan 8, 2020 10:17 AM
Jimmy Beilfuss
Oct 5, 2015 04:18 AM
Delta coupe
Sep 30, 2015 08:11 AM
Bohb
Sep 27, 2015 09:11 PM
