Ghost in my dash
Old May 16, 2008 | 04:47 PM
umrdyldo's Avatar
well junk in the trunk maybe
i mean the outside of the car.
nice catch though
Old May 16, 2008 | 04:52 PM
tru2nrtt777's Avatar
Haha, as soon as I read it I thought of a MR2 with a front and rear trunk.
Old May 16, 2008 | 04:56 PM
K-Man's Avatar
Both the tach and the speedo are electronic gauges that are connected through the ecu. What you are seeing as pulses is the charge bleeding off some of the capacitors within the ecu unit. It is totally normal.
What was really strange was the gremlin in the original ecu programming on the 2005 models that would blink the highbeam and brake light in the dash at totally random intervals every couple days while driving. Made me think I was seeing things for the first 2 months I had the car. A re-flash as the dealer with an upgraded program fixed it.
Old May 16, 2008 | 06:56 PM
Silv3r's Avatar
I was told at the dealership that the trunk knock is the car "checking" to see if the trunk lock is fully engaged.. seems like a half-decent explanation lol
Old May 16, 2008 | 07:07 PM
bgbearcatfan's Avatar
it's some type of self cleaning process for something, i forget. Search for it, it has been explained
#PIC4317C: Noise From The Rear Of Vehicle - keywords canister cold CVS click evap knock L61 LE5 solenoid tick vent - (Jan 31, 2008)
Subject: Noise From Rear of Vehicle
Models: 2006-2007 Saturn ION
2006-2008 Chevrolet Cobalt
2007-2008 Pontiac G5
2006-2008 Chevrolet HHR
2005-2008 Pontiac Pursuit
with Engine RPO L61 or LE5
This PI was superseded to update models and model years. Please discard PIC4317B.
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern:
A noise may be heard from the rear of vehicle; typically 3-5 knocks during initial cold start. The noise may sound like someone outside of the vehicle is tapping on the back window or on the rear exterior body panels.
Recommendation/Instructions:
This noise is from the vehicle's EVAP canister vent solenoid going through the diagnostic cleaning cycle, which is part of the software calibration set-up. Replacing the EVAP canister may not resolve the issue when the vehicle is re-exposed to a cold start. No parts should be replaced. This should be considered a normal condition for 2008 and previous model years.
Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
Last edited by bgbearcatfan; May 16, 2008 at 07:07 PM. Reason: Automerged Doublepost
Old May 16, 2008 | 09:21 PM
TheCaptain's Avatar
Jeese, people worry about the littlest things. If i had a tire fall off, i'd worry. Some needles pulsing? woop-dee-do.
Mine hasn't done either of these, anyway (pulsating needles or clunk in the trunk).
Old May 16, 2008 | 09:37 PM
You should go back and smack them in the face. It is one of two things, if while running it is solinoids in the evap system, if parked it is the fuel pump. Both completely normal unless you have less than 1/4 tank of gas or 3/4 tank of gas and the evap solinoids still sound. The car is not capable of exicuting a evap test unless it is between 1/4 and 3/4 tank.
Old May 16, 2008 | 09:38 PM
ace921000's Avatar
3vil sp1rits in teh dash! oh no'z!
Old May 16, 2008 | 11:22 PM
Evil C's Avatar
lol its normal on like every eletronically controlled gague.
Old May 17, 2008 | 12:39 AM
BlackMachine's Avatar
lol
mine did it today
Old May 17, 2008 | 12:42 AM
  #36
dman090's Avatar
mine has only done it one
Old May 17, 2008 | 12:49 AM
  #37
rudeone79's Avatar
Its just recalibrating itself. Mine did it everytime I turned off the car.
Old Jun 4, 2008 | 01:48 AM
  #38
mrsilent13's Avatar
now i gotta go c if mine does it....lol...just so i could scare the wife and make her think that my car does have a ghost...lol
Old Jun 4, 2008 | 01:52 AM
  #39
2006BlackSS/SC's Avatar
my 06 ss/sc does it what it is when the guages loose total power the servo's / motors go into a rested settled posistion. once u turn on your key they do back to the 0 rpm and 0 mph.
like others have stated there is nothing to worry about i noticed this same problem when i was doing my clearing behind my guages to get ready for a color change..
its totally normal now for the trunk thing i have never herd it
anyways later and have a good night sleep
Old Jun 4, 2008 | 01:57 AM
  #40
eurochevy's Avatar
i think it does it almost every time..mine does if i sit in the car long enough to see it happen
Old Jun 4, 2008 | 02:15 AM
  #41
ColeJJones's Avatar
Bannned
its normal.
  #42
mIkeyG312's Avatar
u guys all have ghosts in ur dashes then =]
Old Jun 4, 2008 | 09:44 AM
  #43
mrsilent13's Avatar
i still havent seen it....ill try and remember to look for it...dam ghost
Old Jun 4, 2008 | 10:24 AM
  #44
mike25's Avatar
just tho power fully cutting off if you dont get out
Old Jun 4, 2008 | 09:36 PM
  #45
pare_john's Avatar
mine does it to/normal
Old Jun 5, 2008 | 11:24 AM
  #46
megaman311's Avatar
mine did it last night..... then the ghost came out of my dash and bitch slapped me.
Old Jun 5, 2008 | 11:28 AM
  #47
john80's Avatar
Originally Posted by megaman311
mine did it last night..... then the ghost cam out of my dash and bitch slapped me.
Old Jun 5, 2008 | 11:40 AM
  #48
Blue_Balt's Avatar
Originally Posted by Nymostwanted187
in other words it happens to alot of people.
In other words, it's not a ghost.
Same happens to me.
Old Jun 5, 2008 | 11:54 AM
  #49
mrsilent13's Avatar
i still cant see the dam ghost
mayb i should wait longer
vjoel2011
Oct 2, 2015 12:11 PM
Turbo6
Sep 30, 2015 09:14 AM
xxenjoi11
Sep 29, 2015 12:36 PM
ashalle2
Sep 17, 2015 04:58 PM
Snail_SS
Sep 11, 2015 01:02 PM
