Ground wires??
Old Aug 9, 2006 | 12:57 PM
Belto's Avatar
Ground wires??
can our car be ground?? has anyone put a groud wire kit on our car and if you have, how because the batery is in the back??
thanx
Old Aug 9, 2006 | 01:08 PM
css9450's Avatar
What, like for an accessory? Just ground it to the metal part of the car - the car is negative-ground, meaning the positive side is "hot" and the circuit is competed by running the negative wire to either the frame or to the negative terminal of the battery.
Old Aug 9, 2006 | 01:23 PM
Belto's Avatar
so just by running a wire from the metal is the same as the neg in the battery? didnt quite understand...
Old Aug 9, 2006 | 01:29 PM
BlwnGP's Avatar
The car is the ground, hence the wires connected to the chassis. By the tires contacting pavement, it provides the ground to an electrically inert object. Adding a "grounding kit" like what is sold on Ebay is a joke and accomplishes nothing but adding more connections that could fail. Save your money. However, if you want to ease your modding urge somewhat and just gotta have it, get some very nice stereo system power cable, such a a zero sized power cable and re-solder/replace the ground cables already present (if you can find them all). However, it is a waste of money and time and will not accomplish any difference. It is an old ricer gimmick that has been disproven many times over (similar to the Tornado air intake).
"Mah groundin' kit adds 10hp!" Yeah, just like stickers do!
Old Aug 9, 2006 | 01:37 PM
Belto's Avatar
didint know that thanx man
Old Aug 9, 2006 | 04:17 PM
BlwnGP's Avatar
Just tryin to save you a few dollars....to be saved up for a turbo kit or something that WILL make a performance difference
Old Aug 9, 2006 | 05:32 PM
Belto's Avatar
thanx man
Tupp
2.2L LAP Performance Tech
Jan 2, 2016 12:04 PM
Oct 20, 2015 09:56 PM
dennis69
Oct 20, 2015 07:39 AM
ernnyyes
Oct 2, 2015 05:16 PM
jmelton327
Sep 26, 2015 10:04 PM
