Having some issues with the balt need help please.
Guys I got a great tune but I think I am running too much timing I am reading about 3.5 degrees max around 5300rpm and then it goes down to 1 or less after 6000prm. I know knock retard is bad for your engine, but how bad is it and can this problem be fixed with some higher octane gas I am running 93 but I have access to some gt100 from sunoco. Also the car is hiccupping every now and then but no knock happens when it hiccuppsm, what can be the problem thanks.
Bump for desperately needing some help.
20 Views and no opinions? Cant someone help?
Last edited by glockglade; Feb 18, 2007 at 11:24 PM. Reason: Automerged Doublepost
Yo, did you notice this at tonight, Could be the cold weather, since you are running much leaner, Im sure Higher octane will help, But I could knock down some degrees as you are running I believe like 16 to 17.
No its been like that since the new injecors are in I need you to come up sometime and re0tune this beast on a better dyno. By the way I am loving the spankings I am giving to these unsuspecting peolpe up here.
Is it finally up and running? We should have a day for you to come up here and retune this thing then you and I should show up at the local race scene and tear some people up. I wanna see your thing shoud be quick the car I beat from 2nd gear roll was a camaro z28 that ran a 13.1 @107! I can't beleive how much quicker this car is now.
roth
Sep 26, 2015 12:16 PM
