Heated mirrors?
You can use the heated mirrors that come with the Chev Impala LTZ. They are the same size and style as the ones on the Cobalts. Only they are heated. You can order these from the GM parts department. Then you can connect them to your rear defogger as mentioned in this post. This is what I am planning on doing.
j
Yes I am going to do the heated seats first, then I will do the mirrors. Once I get that done I will post it.
I will try and find out the exact part number from the guy that will be doing it for me.
Sorry don't know the part number off hand. However, this link should help you out a bit, although their cost is a bit pricey. http://www.newgmparts.com/partlocato...layCatalogid=0
Can you find out if you can just order the "mirror glass with defogger"http://http://www.newgmparts.com/partlocator/index.cfm?action=getJointLocator&siteid=213815&cha pter=§ionids=0,2732&groupid=2740&subgroupid=37 42&componentid=18947&make=6&model=Impala&year=2006 &catalogid=2&displayCatalogid=0 if you already have "electric mirrors"? That would make the conversion / upgrade a lot less pricey!
I'll get back to you on that once I look into it more.
Well, There are the numbers for Impala 06-07 heated mirror glasses: 89046148, 89046149 - for 4-dr sedan, and 88894726, 88894727 - for 2-dr coupe.
They look similar to Cobalt glasses, but it seems their shape is slightly different. The closer to car's body side of triangle is almost vertical on Cobalts but inclined outside on Impalas.
Am I right?
Please someone park your Cobalt near Impala and compare the shape and dimensions of mirror glasses.
Am I right?
Am I right?
Am I right?
I'm not sure... They could be same. I have only a picture of Imapala's mirror and it is taken not from a straight angle.
You really better check yourself, go find Impala. I simply can't do this because there are no Impalas where I live.
Actually, I am going to take my Cobalt in next week to the dealer for an oil change. I will check out the Impala's that they have there.
