Help With Install B&M Shift plus
Old Feb 12, 2009 | 09:52 PM
Nick1988's Avatar
Anyone in the Maryland area mind meeting up with me and helping me install this b&m shiftplus i have no knowledge of wiring things up. you will be compensated.
Old Feb 16, 2009 | 02:57 AM
Nick1988's Avatar
bump..
Old Feb 17, 2009 | 03:05 PM
shawn672's Avatar
not unless you want to drive to NY
wired up 2 of these already, it's pretty easy. but i guess if you've never done any electrical work it could be confusing
Old Feb 17, 2009 | 03:11 PM
wdsoccer's Avatar
LMAO. its so easy. just follow the instructions. not hard at all.
Old Feb 18, 2009 | 12:31 AM
HunterKiller89's Avatar
theres two wires in the harness that you attach it to. nothing crazy.
Old Feb 19, 2009 | 01:32 PM
Nick1988's Avatar
im sure its easy, ive just never done anything with wires so i dont know where to begin.
Old Feb 19, 2009 | 01:59 PM
it came with quick connectors, right? just clip them on to the correct wires... done
dont be afraid to try and work in new areas. Worst comes to worst, you cut the wire in half (thats pretty unlikely), and you find a friend to solder them back together. No big deal
Old Feb 19, 2009 | 02:56 PM
shawn672's Avatar
no, worse case scenario, your automatic wont shift out of 1st gear and you can barely drive down the street..
Old Feb 19, 2009 | 03:39 PM
mkulrey13's Avatar
...if you cant attch 2 wires with quick connects...stop modding and sell your shift+... come on...are you serious?
Old Feb 19, 2009 | 03:57 PM
shawn672's Avatar
shrug, those wires are tight, and he has absolutely no experience with electrical work
hes cautious, maybe a bit too much...but if he does screw up, he really cant drive the car until it's fixed
(the how two on this site shows 05/06, the colors were different for 07, so i taped my wires to the shift+ before i soldered them, and half way around the block one of them came loose and forced the car from 2nd to 1st and wouldnt upshift)
Old Feb 19, 2009 | 10:03 PM
and what exactly would he screw up? if you dont cut the stock wires in half (you shouldnt be doing that...you should just splice the shift+ wires in parallel with the stock ones...so idk what you fucked up), then its impossible for anything to go wrong.
Old Feb 20, 2009 | 09:26 AM
shawn672's Avatar
It doesn't say what year cobalt he has, and if he goes by the HowTo on this site, the wire colors are different, I later found the right colors on page 2 or 3 of that how to post.
if he cuts the wires on accident, which is easy to do, they're thing wires with thick insulation (on the 07s anyways, ive never played with 05-06).
Sure it's pretty easy, but if he does mess it up, he might have big problems...
OP: Do you have any friends with any basic wiring knowledge? Doesn't even have to be car related.
RaginChopsuey
Oct 27, 2015 01:27 PM
dennis69
Oct 20, 2015 07:39 AM
justinchinn
Oct 2, 2015 12:18 PM
2009blackSS
Sep 30, 2015 05:57 PM
DocSvensk
Sep 27, 2015 02:24 PM
