I don't know if this is the correct place to post this but...
I've been trying to figure out what has been done to my recently bought Cobalt SS S/C, but I can't quite figure it out.
The things that I have found/have been stated by the seller are the following
ZZP Lowering Springs
ZZP Shorty Headers
ZZP Catless Downpipe
Injen CAI
Hurst Short Throw Shifter
Possible Tune
Possible Pulley Size Reduction
I say possible tune because the previous owner said the car revs to 7,000, not 6,500 and the catless downpipe does not throw a check engine light.
I'm pretty confident the pulley is aftermarket, as from what I understand stock pulleys are pressed on not bolted on. No markings on the pulley, is it a possible GM Stage 2? Pulley Top-down view of the pulley, it is rubbing Injectors Not a dual-pass endplate Intake Headers/Downpipe Full engine bay
Stock pulley is pressed on. That looks like a gm stage 2 pulley and gm stage 2 injectors. If you look closely at the face of the pulley it should say what size it is I believe.
I have looked at the face of the pulley but I haven't seen any markings of the sort. The pulley is rubbing against the tensioner bracket and has shown signs of it rubbing like the black paint coming off. I doubt the stock pulley was designed to rub.
It wasn't. I had a GM stage 2 on my old 05. It looked really similar to yours. I don't have any pictures of the pulley...
If that is the case, it is different from the '05 because those were not pressed on. I stand corrected.
That looks like a rather large pulley. I'd almost say near stock sizing.
This is my 2.8" pulley. I don't remember where I got it in 2006, but it was marked with the millimeter sizing indented.
EDIT: Actually, if I remember correctly, the indent on my pulley was made to LOOK like the GM Stg 2 Pulley, which was marked with a "77.9 mm".
EDIT2: I was correct, here's a GM Stage 2 pulley:
And here's the stock pulley off of a 2007 SS/SC:
All Cobalts came from the factory with a pressed on pulley. The Stg 2 kit came with a new hub and bolts expressly for this reason. Also, stock 2007 pulley posted above.
