HELP Vibration Coming From Front End
Old Jan 27, 2015 | 11:34 PM
blackwhine622's Avatar
So for the past few months I have had an annoying vibration and noise coming from the front of the car. It has progressively gotten worse. The car is lowered on coilovers and is on PF01's. Everyone had pointed me in the direction of a bad wheel bearing and said that it is the opposite side of the car from which it is worse when turning. It is worse when turning left so I replaced the passenger side hub assembly with a TIMKEN. Did not fix the problem whatsoever. The vibration and noise completely stops when I make a right turn. I took the good hub assembly that I removed from the passenger side and put it on the driver side to see if the driver side hub was the problem and that still didn't fix it. This is driving me crazy. Any suggestions?
Old Jan 27, 2015 | 11:36 PM
Sl0wbaltSS's Avatar
Meadowvalien
Aug 17, 2017 06:32 PM
chefhhr
Oct 26, 2015 10:36 PM
Tupp
Sep 29, 2015 11:07 PM
Builttss
Sep 21, 2015 04:29 PM
OrngBalt
Sep 16, 2015 07:45 PM
