hid wiring ?
Old Oct 12, 2011 | 10:36 PM
JOHNNY C's Avatar
hid wiring ?
Just got this kit and need to know where these wires plug into. I know the yellow ended plugs go into the ballast but what about the two others. This is a relay. I also bought the harness just in case i needed it.I know the other two go to the pos. & neg. on the battery.
And here is the harness:
Old Oct 12, 2011 | 10:57 PM
LS6Rally's Avatar
my gues would be for the High/low Shutter. are these Retros or hi/low 9007's?
or the factory fog light harness.
Old Oct 12, 2011 | 11:01 PM
keiserX13's Avatar
What do you have for HIDs? those are 2 different harnesses
where did you get them from?
top is a universal single beam harness
bottom is duel beam harness
Old Oct 12, 2011 | 11:04 PM
TommyP's Avatar
AWD > FWD
OK, what are you installing EXACTLY? Because I can tell you right now you don't need both of those harnesses.
Old Oct 13, 2011 | 06:48 AM
JOHNNY C's Avatar
I'm installing high/low hids.The second set comes with the plug that fits into the OEM plug. That's where you see the loose wires. But the wire colors are blue,brown,yellow. one wire should be the + , one should be high beam and one should be low beam which is which ?
Old Oct 13, 2011 | 08:00 AM
keiserX13's Avatar
Old Oct 13, 2011 | 05:32 PM
JOHNNY C's Avatar
In my case it should be center brown left blue right yellow. correct?
Old Oct 13, 2011 | 05:37 PM
i plugged and played with mine, just knowing black went to brown. try it one way, if that doesn't work try the other way
Old Oct 13, 2011 | 05:39 PM
TommyP's Avatar
AWD > FWD
the picture above is correct, that picture is from a cobalt.
Tupp
2.2L LAP Performance Tech
Jan 2, 2016 12:04 PM
dennis69
Oct 20, 2015 07:39 AM
ernnyyes
Oct 2, 2015 05:16 PM
c_m_shooter
Sep 27, 2015 04:40 PM
jmelton327
Sep 26, 2015 10:04 PM
