How to disconnect the battery?
Old Jul 8, 2007 | 12:20 AM
Hokage's Avatar
I know this is probably going to sound stupid. I have an 07 SS/SC and I'm about to install the AEM intake. I want to disconnect the battery but I'm not sure if you just have to disconnect the negative terminal, red terminal, or both?
Old Jul 8, 2007 | 12:24 AM
AjSS's Avatar
To install an intake?
But to answer your question, just the negative.
Old Jul 8, 2007 | 12:39 AM
Hokage's Avatar
Ya, I want to disconnect the battery so the pcm can reset and relearn with a more agressive program.
Old Jul 8, 2007 | 12:44 AM
RaineMan's Avatar
just pull the negative (black) for a few minutes... that will allow the computer to clear.
Old Jul 8, 2007 | 02:04 AM
DoubleClutchin_ION2's Avatar
always use the negative, it does not emit a spark if it touches metal, thus safer...
i think it is actually a good idea to remove the ground, even when just cleaning the engine bay, because you never know anymore...
Old Jul 8, 2007 | 02:11 AM
bluecobaltss06's Avatar
Ha, it does emit a spark if it touches metal, but it'snothing to worry about. It's a small spark and does no damage. But you don't really need to disconnect it for an intake install.
Old Jul 8, 2007 | 02:13 AM
sick06cobalt's Avatar
^^^ I was bout to say I didnt do it with mine when i installed a injen CAI on my 2.2.... so i mean to each their own
Old Jul 8, 2007 | 02:16 AM
06' SS2SS's Avatar
In the directions it tells you to disconnect the battery. This is so the ECU will reset. If you don't, you could throw a code.
Old Jul 8, 2007 | 02:22 AM
I didnt and i still havent thrown a code... INJEN > all intakes
Old Jul 8, 2007 | 02:24 AM
06' SS2SS's Avatar
I think the SS/SC's have a bigger problem with this.
Old Jul 8, 2007 | 02:25 AM
I think you are correct sir
Old Jul 8, 2007 | 02:27 AM
killianss's Avatar
hey keep us updated if you throw a code or not, im going to be installing the same intake on my 07 sc on wednesday or thursday. good luck!
Old Jul 8, 2007 | 03:17 AM
Kritter's Avatar
He'll throw a code regardless...should have went with the Injen.
Old Jul 8, 2007 | 04:04 PM
Hokage's Avatar
I finshed the install a few hours ago. The supercharger whine is louder than I had expected. So far no CEL's thrown and the only thing is that the RPM's seem to be slightly different until maybe the computer relearns. What i mean is that during idle the RPMs go up and down but not by much and I had to give it a bit more gas than normal when I'm moving from a dead stop.
WhineSSbaby
Sep 1, 2020 12:39 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Meadowvalien
Aug 17, 2017 06:32 PM
grampss
Sep 27, 2015 08:51 PM
c_m_shooter
Sep 27, 2015 04:40 PM
