idle shacking
Old Jun 14, 2007 | 01:53 PM
h0l0caust's Avatar
idle shacking
My problem is, "if its a problem"
when my engine idle, i can feel a lil shaking caused by the engine, its no a constent shaking like a vibration, that shaking occur every 2 -3 secondes and i can feel the whole car shaking, its minor but still, only by starting me AC, its stop, because the AC is suckin a lil bit a power from the engine and it stop doing it. i also noticed that shakin on my GF 2004 sunfire, it is normal, anyone have the same problem?
Thanks
Old Jun 14, 2007 | 01:56 PM
cheesetits's Avatar
It might be dirty gas.
Old Jun 14, 2007 | 01:59 PM
Acidangel_5.0's Avatar
idle surge.. its no biggy
Old Jun 14, 2007 | 02:10 PM
h0l0caust's Avatar
i tryied different gaz from 91, 93, 94 from 3 diff gaz station, its not badgaz
what is the cause of idle surge?
well, if you mean the rpm going between 800 and 1250 rpm. sometimes and stopping, that is not what i am talking about, when the shaking is occuring, the rpm is totally stable. so a rpm variation is not the cause of the issue.
Old Jun 14, 2007 | 02:56 PM
ya.. rpm variance... but if thats not it ...
hm...
check your belt line... make sure the belt isnt cracked.. make sure your pulleys are all okay... gonna have to just start knocking **** out 1 by 1
Old Jun 14, 2007 | 03:04 PM
M-Dub's Avatar
Do you have a Torque Damper or Solid Motor Mounts..... because if you do that will cause it to shake or idle roughly!
Old Jun 14, 2007 | 05:58 PM
SSdan's Avatar
Mine does it too, especially after a hard run. I think it's just the standard motor vibrations.
Old Jun 15, 2007 | 12:14 AM
ptrblkz24's Avatar
It could be a bad motor or trans mount.
Old Jun 15, 2007 | 12:39 PM
jbounce's Avatar
Mine does it as well.
When I'm at a traffic light. Vibrations on the passanger side are stronger than on the driver's side, however, they are constant, they do not go away.
Also, once in a while PRMS jump between 800 - 1250 for a few seconds and then settle down(also at a complete stop).
Any ideas?
Old Jun 15, 2007 | 12:43 PM
p7x's Avatar
p7x
its probably nothing but you can check spark plugs and maybe clean injectors.
Old Jun 15, 2007 | 01:00 PM
h0l0caust's Avatar
ill try to clean the injector and change my spark plugs, cannot be bad for the engine enyway
hacadacalopolis
Oct 28, 2015 06:09 PM
tomj77
Oct 4, 2015 11:39 AM
jimbofug007
Oct 2, 2015 12:06 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
n20saturn
Sep 21, 2015 01:50 AM
