Ignition lock cylinder replacement help.
Old Dec 7, 2009 | 02:39 PM
SSRedSC's Avatar
The lock cylinder on my 05 balt is bad. Having one hell of a time getting the key to go all the way in, then turn forward. I have a new key, that didn't help, so I have to replace the cylinder. Has anyone done this on the balt? I have done a few before.
My biggest question is do I have to remove the steering wheel?
Old Dec 8, 2009 | 07:11 AM
dorman68's Avatar
My coworker had the same issue on her 05 Cobalt. It ended being the shifter (auto trans). I did some searching on other websites and there is a small microswitch on the shifter or a tab near it which goes bad and causes difficulty shifting or difficulty of key operation. GM has a service bulletin addressing the same issue you are experiencing. It is bulletin no. 6-07-30-004c. Just a thought, hope this helps. Here are some links to this issue.
http://www.carsurvey.org/reviews/che...2476/comments/
https://www.cobaltss.net/forums/problems-service-maintenance-69/my-car-ate-my-key-142606/
http://www.automotiveforums.com/vbulletin/t920995.html
http://www.***************/forums/ch...ls-unlock.html
Old Dec 8, 2009 | 10:41 AM
SSRedSC's Avatar
Thanks bud, but that is not the problem. Mine is a standard. The key comes out just fine, just doesn't go in and turn the ingnition. I'm thinking it had to be the lock cylinder
Old Dec 8, 2009 | 10:47 AM
BlackARCA06's Avatar
I had my ignition cylinder replaced in my 06 balt! my key had troubles going in and turning and it wouldnt come out! But GM fixed mine for free!
Old Dec 8, 2009 | 12:01 PM
SSRedSC's Avatar
Does anyone have a manual that they could look it up for me? It would say step one remove the steering wheel.
Unfortunately they are not about to fix it for free.
Old Jun 2, 2011 | 05:16 AM
Truckerz88's Avatar
2006 Chevrolet Cobalt LS Comments (r102476)
My car ate my key! - Cobalt SS Network
05 Cobalt shifter doesn't unlock - Car Forums and Automotive Chat
I'm really having hard time replacing my ignition locker cylinder thanks for all these links i'll really make use of this... Thanks!
agentirons
Oct 16, 2015 02:11 AM
justinchinn
Oct 2, 2015 12:18 PM
Trav3480
Sep 28, 2015 02:46 PM
Sep 28, 2015 12:51 PM
SlowSaturn
Sep 28, 2015 11:03 AM
