Koni on stock FE1 Suspension
Old Aug 23, 2018 | 06:27 PM
63 Nova SS's Avatar
What's with the Black shock shaft?
Old Aug 23, 2018 | 06:40 PM
G5ALIVE's Avatar
what do you mean?
Didnt feel like painting the insert housing, not gonna see it anyway
Old Aug 23, 2018 | 06:46 PM
G5ALIVE's Avatar
shock shaft should be stainless steel colored if Im thinking what you mean.
It does look like theres something at the top of the shaft brown, not sure what that is maybe a reflection
Old Aug 24, 2018 | 09:50 AM
G5ALIVE's Avatar
Anyway I did order some lowering springs 1 inch front, two inch lower rear made by ZZP for the 2.2l.
Might not not be the answer but a good place to start.
Judging my the amount that shock extended, it is sitting way to compressed at ride height.
Old Aug 24, 2018 | 08:04 PM
63 Nova SS's Avatar
Yeah I don't get that. If you put lowering springs in, it will make it worse. Are you missing end links? Did he cut the housings wrong?
Old Aug 24, 2018 | 08:06 PM
63 Nova SS's Avatar
The shafts on my konis are polished, why do yours look black in the pic?
Old Aug 25, 2018 | 10:24 AM
G5ALIVE's Avatar
My links are fine. The shocks were cut properly( I took a leak under the boot) I do think the koni shafts are smaller than my fe1, probably more the height of an fe5 shock. so I will try lowering it like the 99%. Maybe it will work maybe it won’t, getting some conflicting answers but hey I gotta move forward
G5ALIVE's Avatar
Peak*
Old Aug 25, 2018 | 10:26 AM
G5ALIVE's Avatar
Literately done with any suspension mods after this they have all gone down the *******, really should’ve just stuck with engine mods and maintenance... oh well. Live and not learn
Old Aug 26, 2018 | 07:05 AM
63 Nova SS's Avatar
It happens some time when you mod a car. Sometimes you like it afterward and other times not.
Old Aug 26, 2018 | 05:29 PM
  #36
cluelessk's Avatar
Our climate is hard on cars.
It looks like it's had a hard life. There's probably a ton of maintenance to do.
Old Aug 29, 2018 | 07:16 PM
  #37
G5ALIVE's Avatar
It hasn’t had that hard a life.. it’s been in the family three generations.
Was given to my parents at about 2000km, there after it was given to me a about 78000km last year.
Now me and my brother damaged the car visually, all the scratches and dents= learing how to winter drive long ago.
And I probably did a number on the suspension not caring to much about hitting bad roads really fastż
been in one collision, I think grille, headlights and impact absorber were replaced, facia was reused as it wasn’t torn just bent.
When I got it the motor was so sluggish omg.
Re did all fluids, new battery, spark plugs, ignition coils, new maf, and the motor was reborn. (Other stuff to I can’t recall)
Next started my journey to the aftermarket realm of cobalts and the like.
I estimate now with a full exhaust, headers downpipe and cat back CAI, a tune, upgraded Ignition this car is sitting at about 150hp to the wheels, ~200 to the crank, bout 50 over stock.
SOLVED: FE1 suspension with koni shocks:
you need lowering springs. Stock springs are too long for koni.
Had them installed and well it’s gonna take some getting use to being lowered but my noise is gone, and wow does it handle better!
and the cars not slammed so I’m happy
Old Aug 29, 2018 | 07:47 PM
  #38
G5ALIVE's Avatar
or vice versa, koni shocks are too short for stock fe1 springs
Wangspeed
Jul 22, 2017 10:55 AM
blackphoenix
Apr 29, 2015 10:12 AM
znew
Apr 2, 2012 11:48 PM
musifreak190
Dec 8, 2008 01:35 PM
Raiden8816
Mar 14, 2008 03:42 AM
