Lil Blacky’s official TVS build thread(long post)
Old Jan 29, 2018 | 10:54 PM
  #301
Henry3959's Avatar
You don't want to send / force coolant into the IC tube. It will trap it in there while running and heat soak that water. The tubes are not plugged on the exit end as they gravity drain out anyway.
I know you said your running 2 pumps but I would still be worried that you will not flow enough volume to keep a constant pressure on all 4 tubes. The resistance is now 1/4 of what it was. 2 pumps in series does nothing for volume and that's what you need more of in this parallel flow style. If the combined area of the 4 tubes openings, 64 in total are larger than the smallest area anywhere in your cooling system path you will not have enough flow.
Old Jan 29, 2018 | 11:08 PM
  #302
chevygirl2006's Avatar
Almost done. Will finish up tomorrow
Old Jan 29, 2018 | 11:10 PM
  #303
I’m running dual pumps just because my tank is in the trunk and there’s a ton of hoses now. Need a stronger flow. And I did mine exactly how jason makes all his. Awesome temps
Old Jan 29, 2018 | 11:16 PM
  #304
Henry3959's Avatar
I like your co-pilot :-)
Well, I wish you luck. This flow style benefits 1/4 milers most.
Old Jan 29, 2018 | 11:34 PM
  #305
I’ll post the temp results when I find out.
Old Feb 1, 2018 | 02:04 PM
  #306
ProfDNS's Avatar
I know it's only been 72 hours but do we get vids?
Old Feb 1, 2018 | 02:52 PM
  #307
We primed the engine last night to get the motor oil running through. Tonight we are going to start it
Old Feb 1, 2018 | 03:50 PM
  #308
63 Nova SS's Avatar
Wish you luck. Will be good for you to hear it running.
Old Feb 1, 2018 | 04:11 PM
  #309
I’m ready to have a car again. It’s been down 4 months
Old Feb 1, 2018 | 04:56 PM
  #310
jdbaugh1's Avatar
For me anyway first startup is always so nerve-racking. Hope everything goes smoothly for you.
Old Feb 1, 2018 | 07:25 PM
  #311
ProfDNS's Avatar
+1
4 months is too long already
Old Feb 1, 2018 | 07:59 PM
  #312
Car won’t start because my injectors weren’t firing. We have fuel pressure and compression and spark. Took injectors out and they are all clogged. We cleaned them and got one to work. The other 3 have corrosion all inside of them. Thank you e85.
Old Feb 1, 2018 | 08:30 PM
  #313
alwayyyyys clean/test injectors prior to new install wether they are used or even new.
Old Feb 1, 2018 | 08:37 PM
  #314
$100 to have them cleaned and if they can’t get them flowing they don’t charge you. We are putting my old 80s back in for now. My 160s were expensive. Hope I don’t need new ones.
Old Feb 1, 2018 | 11:22 PM
  #315
thats not a bad deal at all.
Old Feb 2, 2018 | 06:16 AM
  #316
63 Nova SS's Avatar
I'm so ocd that even though I drive my car a couple of days a month in the winter, I swap from e47 back to 93. Seen to many horror stories of corrosion and moisture with e fuels.
Old Feb 2, 2018 | 07:55 AM
  #317
jdbaugh1's Avatar
Any easy way for a home gamer to do this themselves?
Old Feb 2, 2018 | 01:21 PM
  #318
ProfDNS's Avatar
Mighty Car Mods on YouTube have a pretty easy way of cleaning them. I don't know the technical jargon for how they did it. If I find the video I'll link it
Found it.
Old Feb 2, 2018 | 01:38 PM
  #319
Ran into an issue. Not sure what it is but I’ll be back with an update soon.
Old Feb 2, 2018 | 02:12 PM
  #320
Henry3959's Avatar
E85 cars have corrosion-resistant fuel systems with upgraded plastic and rubber parts. If you run E85 in anything that wasn't, anything that can corrode, will. Anything that can rot, will. Anything that can deteriorate, will.
Old Feb 2, 2018 | 02:36 PM
  #321
My fuel system is fine.
Old Feb 2, 2018 | 03:04 PM
  #322
Henry3959's Avatar
Injectors are part of your fuel system
Old Feb 2, 2018 | 03:10 PM
  #323
I know that but my stock stuff is fine. All my lines etc and I run a tank of 93 every so often. It was my fault for leaving the injectors in there with e for 4 months just sitting.
Old Feb 2, 2018 | 03:56 PM
  #324
Henry3959's Avatar
The same damage is occurring in the tank..
Old Feb 2, 2018 | 06:21 PM
  #325
Not going to stop me from running e85. Lol
