Lil Blacky’s official TVS build thread(long post)
Old Mar 9, 2018 | 02:43 PM
  #476
Henry3959's Avatar
Will bags push some weight forward?
Old Mar 9, 2018 | 02:45 PM
  #477
Henry3959's Avatar
Installed my lower AC Line last night... What a difference in room
Old Mar 9, 2018 | 03:01 PM
  #478
chevygirl2006's Avatar
Drag bags keep the rear from squatting
Old Mar 9, 2018 | 06:32 PM
  #479
63 Nova SS's Avatar
They help with rear squatting. On my car at 4psi of boost off the line it still transfers some weight but I have more torque than you, so you maybe ok.
Old Mar 10, 2018 | 06:10 PM
  #480
My alternator took a poo
Old Mar 10, 2018 | 06:20 PM
  #481
jdbaugh1's Avatar
Where you still using your old one and spinning it backwards?
Old Mar 10, 2018 | 06:28 PM
  #482
No I have the lsj one and the lsj belt setup. 6 rib conversion
Old Mar 10, 2018 | 06:32 PM
  #483
63 Nova SS's Avatar
That sucks, are you at the Texas meet? Seems like it's always the little things that get you.
Old Mar 10, 2018 | 07:18 PM
  #484
No I’m at home
Old Mar 10, 2018 | 09:15 PM
  #485
Well it wasn’t my alternator Not my battery either. So something with my wiring
Old Mar 11, 2018 | 05:00 AM
  #486
Henry3959's Avatar
Old Mar 11, 2018 | 07:44 AM
  #487
jdbaugh1's Avatar
When I went back together with my car I had all the symptoms of a failing alternator. I started the nut down to attach the main hot cable to the alternator but never tightened it. It was one of my dumber mishaps.
Old Mar 11, 2018 | 12:30 PM
  #488
We took everything apart last night twice. New alternator did the same thing. We tested all the wires and everything was good. Started the car up and it was making a weird sound. Kinda sounded like a boost leak but I think it was the alternator making the sound. Drove it today and the voltage randomly went back up to normal and it’s fine now. No noise either. I was going to take it apart again today but I’m not going to touch it since it’s working now.
Old Mar 11, 2018 | 02:10 PM
  #489
Henry3959's Avatar
The whistle noise is the alternator charging it's ass off as the battery was probably low. As long as everything is ok now, the whistle goes away.
Old Mar 11, 2018 | 03:09 PM
  #490
Seems like it’s ok now. Weird.
Old Mar 12, 2018 | 06:18 AM
  #491
jdbaugh1's Avatar
I'd double check grounds and connections.
Old Mar 12, 2018 | 10:44 AM
  #492
Well it’s doing it again
Old Mar 12, 2018 | 11:50 AM
  #493
Henry3959's Avatar
I don't remember if HPT can turn the L terminal on and off and I was just in there last night setting up my fan speeds. That's what commands charging. You can take a Volt Meter to the L terminal and see if there is voltage there.
Is the battery indicator on?
Any codes?
The alternator has a great ground just by bolting it up.
As you probably know, the alt. Battery terminal connects to the starter battery terminal.
Old Mar 12, 2018 | 12:55 PM
  #494
No the battery light isn’t on. Just check charge system. We have tested wires. But we have extra harnesses from another car so going to just change them and see. Changing the wire from the alternator to starter and the one that goes to the trunk to the battery. I think something may be grounding out. Like a wire. We were driving home last night and my headlights turned off and back on again and looked at my gauge and voltage was low again.
Old Mar 12, 2018 | 02:54 PM
  #495
Henry3959's Avatar
Is the alternator brand new? Even if that's the case it could be a defective reman.
There are tests that can be done rather than replacing wiring and parts.
Old Mar 12, 2018 | 03:52 PM
  #496
New alternator and my old one is doing the same thing
Old Mar 12, 2018 | 04:23 PM
  #497
Henry3959's Avatar
What kind of battery are you running and is it good. CS alternators do not like sulfated batteries.
Make sure when you were working on the pump that the current sensor wires on the ground cable weren't damaged.
Old Mar 12, 2018 | 04:42 PM
  #498
Battery is a couple years old. I’ve never had issues with it. And yes it’s good
Old Mar 13, 2018 | 12:56 PM
  #499
Henry3959's Avatar
Let us know what you find... Hopefully the PCM didn't **** the bed.
I checked last night... You can turn the L line off and on in HPT.
Old Mar 13, 2018 | 03:05 PM
  #500
I have an extra pcm
