Lil Blacky’s official TVS build thread(long post)
Old Jan 2, 2018 | 03:13 PM
  #151
chevygirl2006's Avatar
That’s what I said. It will hold at 3k while the gas is all the way to the floor. At the staging lane with the line lock all I have to do it floor the car and the rpms will hold as high as they will fo(around 3k) then let off the button to disengage the line lock. I didnt say I would go past 3k.
Old Jan 2, 2018 | 05:10 PM
  #152
06blackbalt's Avatar
You still have to press the barke pedal tho right?
Old Jan 2, 2018 | 05:14 PM
  #153
To engage the line lock yes. But then I can left off the brake. I have to hold a button and then let go and the car launches.
Old Jan 2, 2018 | 05:19 PM
  #154
Oh okay I gotcha
Old Jan 2, 2018 | 05:31 PM
  #155
Going to see how strong automatic axles are.
Old Jan 2, 2018 | 10:09 PM
  #156
63 Nova SS's Avatar
Don't have a trans brake in my Nova but have a 2 step and line lock and once you floor the brake pedal it holds pressure in the line so you can take your foot off the pedal. The one thing that yours might do that mine wouldn't, is build boost on the TVS. Mine is na.
Old Jan 3, 2018 | 08:13 AM
  #157
jdbaugh1's Avatar
I'm not trying to be a douche here, honestly just trying to understand this. I thought 2-step limits rpms by drastically retarding ignition timing/reducing torque and I also thought the primary purpose was to get as much exhaust gases flowing as possible to spool up a Turbo. So in the application of drag racing without a turbo is the 2-step primary function to limit the torque or amount of pre-load on the trans? Say in this case if you didn't have the 2-step what would happen? Would the rpms actually go over 3k and overload the line lock or engine? Or would it hit an equilibrium point close to 3K with maximum pre-load?
Old Jan 3, 2018 | 09:31 AM
  #158
Henry3959's Avatar
There are several types of Rev limiters today. A standard rev limiter limits max RPM by either cutting out fuel, spark or both. Also used by manufacturers since the very early 90's to avoid over-rev in neutral or park only
A two step as in its name has 2 adjustable RPM limits. One for launching and a higher one for shifting to avoid over rev. Again this can be achieved by cutting out spark or fuel.
For anything but a turbocharged engine it is preferred to cut out fuel to avoid backfires and the rinsing down of cylinder walls.
For turbo applications, the first stage of a two step or better known now as an anti-lag system shuts down the ignition only at a slower rate than a rev limiter or by retarding the ignition timing. The preferred method today for turbocharged engines is to retard the timing so much that little power is made but the burning process continues even as the exhaust valve is opening, aiding in turbo spooling. Rather than a cyclic pop or miss you get a random pop or explosion.
If your NA or supercharged, I wouldn't recommend an anti-lag system to avoid unnecessary exhaust system strain.
Old Jan 3, 2018 | 10:29 AM
  #159
63 Nova SS's Avatar
What HGT said. In my Nova it would allow me to hold the rpms just under what the converter would launch at, and then allow me to have a top end rev limit to keep from overrevving. In the newer cars you can set the rev limiter in the computer so it's not as big of a deal.
Old Jan 3, 2018 | 10:41 AM
  #160
jdbaugh1's Avatar
Is it somehow connected to your line lock or trans brake so it knows when you want to take off?
Old Jan 3, 2018 | 11:18 AM
  #161
What nova said and ya mine is going to be on the same button. And there’s a kill switch to turn it off and on when you want to use it.
Old Jan 3, 2018 | 07:52 PM
  #162
63 Nova SS's Avatar
I had a hurst or b&m shifter handle that had a pre wired button on it, sweet setup. Wired line lock and 2 step to the button so that it activated both at the same time. When I let off the button it went to the 6,500 high rev limiter.
The Cobalt I just hold the ebrake and let the computer do the high limit and wot box do the starting line stuff.
Old Jan 8, 2018 | 02:24 PM
  #163
Motor is ready to go in. We are just waiting on the transmission to get here from Ohio. It’s in a car we bought. The shipping company was supposed to pick it up dec 26 and 2 times after that and they keep giving us the run around. They canceled the pick up and now we are looking for a new driver. So motor going in is being delayed because we don’t have the trans. We are putting both in at the same time to make things easier.
Old Jan 8, 2018 | 03:34 PM
  #164
63 Nova SS's Avatar
Sucks being at someone's mercy.
Old Jan 8, 2018 | 03:59 PM
  #165
WE are just going to put the motor in now and then swap the trans whenever it gets here. I’m tired of waiting. It’s been 3 months without a car.
Old Jan 9, 2018 | 05:11 PM
  #166
Viperoni's Avatar
Sweet build!
I bet it'll leave hard with that 3k stall torque convertor... and the bigger displacement motor too lol
Old Jan 9, 2018 | 05:48 PM
  #167
Motor is going in today. I’ll update later
Old Jan 9, 2018 | 06:37 PM
  #168
Henry3959's Avatar
Is your converter going to have lock-up? That would really help with highway driving and help keep the fluid cooler.
Old Jan 9, 2018 | 07:44 PM
  #169
63 Nova SS's Avatar
I'm thinking 4200 would be even better!
Old Jan 9, 2018 | 10:25 PM
  #170
Sharkey's Avatar
3k stall isnt real high for a 4 cylinder. gm actually had a converter for the old 3 speed th125 that stalled at 3000 for a weak 4 cylinder, i think it was a 2.0l ohv from the 80s. that converter can be put into a 4t45e as a budget high stall as long as you change the lockup strategy from pwm to on/off. 4200rpm would be good for the track, but a pain for street driving.
Old Jan 10, 2018 | 10:42 AM
  #171
Old Jan 10, 2018 | 10:59 AM
  #172
jdbaugh1's Avatar
Very nice. Excited to see her chooch. Put up some vids of some pulls or burnouts whatever when ya get it done.
Old Jan 10, 2018 | 11:25 AM
  #173
ITs going to be a few weeks. We are doing a wire tuck
Old Jan 10, 2018 | 11:29 AM
  #174
ProfDNS's Avatar
I keep coming back to this thread to check out the workmanship on this and being blown away every time. I too want to see some burnout videos in the future!
Old Jan 10, 2018 | 01:16 PM
  #175
ILL be posting drag strip videos at tx2k18 this year. And dyno Numbers. It’s in march
