Lil Blacky’s official TVS build thread(long post)
Old Jan 13, 2018 | 05:05 PM
  #201
jdbaugh1's Avatar
Though I have done it, hours on interstate doing 85 with the windows rolled down kind of sucks. I won't delete my AC until I gut the interior and go full race car. It just gets too damn humid here. I don't mind dry heat at all and windows work then. However moving air doesn't cool your body very well when it is so damn humid your sweat won't evaporate. The AC compressor is essentially just an idler pulley when it isn't turned on anyway.
Old Jan 13, 2018 | 09:10 PM
  #202
chevygirl2006's Avatar
Old Jan 13, 2018 | 09:37 PM
  #203
Henry3959's Avatar
Clean that GM heat exchanger out.
It looks like it doing a better job blocking air flow than anything else.
Old Jan 13, 2018 | 09:39 PM
  #204
CLEan it out?
Old Jan 13, 2018 | 09:40 PM
  #205
I’m putting a newer looking one on it. I have an extra
Old Jan 13, 2018 | 09:42 PM
  #206
Henry3959's Avatar
Remove it and pressure wash it from the back side with a good engine degreaser. It looks like it has a lot of debris in it.
Old Jan 13, 2018 | 09:43 PM
  #207
Henry3959's Avatar
Did you go with a dual fan shroud? Finished mine today and both fans operate just like the SS.
Old Jan 14, 2018 | 10:00 AM
  #208
Yes. I bought one but it’s not here yet
Old Jan 15, 2018 | 11:44 AM
  #209
Lsj dual fans are in
Old Jan 15, 2018 | 11:45 AM
  #210
Also swapped to lsj ac lines
Old Jan 15, 2018 | 11:50 AM
  #211
Henry3959's Avatar
What's different about the LSJ AC lines?
Old Jan 18, 2018 | 10:36 PM
  #212
Henry3959's Avatar
Was just looking at some of your pics... did you replace any of the timing chain / gear components?
The chain looks like it is very stretched and the gear teeth are sharp. That chain should be riding that gear down the whole side.
Old Jan 19, 2018 | 06:35 AM
  #213
jdbaugh1's Avatar
It's possible her tensioner wasn't activated yet.
Old Jan 19, 2018 | 07:24 AM
  #214
It wasn’t activated yet and it’s a brand new chain
Old Jan 19, 2018 | 07:41 AM
  #215
Oh and the lsj ac line has different bends and fits better up front. It’s no longer pushed up against my fans like the 2.4 one was
Old Jan 19, 2018 | 07:44 AM
  #216
This thing. Lsj lines are under my manifold now
Old Jan 19, 2018 | 09:07 AM
  #217
Henry3959's Avatar
I like that fit much better!
Is it a perfect fit?
Old Jan 19, 2018 | 10:52 AM
  #218
yup goes right on
Old Jan 20, 2018 | 02:35 PM
  #219
Henry3959's Avatar
I know the whole nine yards is damn expensive OEM but those teeth look sharp. Mine have 123,000 NA mild miles on them and are all pointed. No way could I put new parts on old parts. If I didn't have GM warehouse connections I don't know if I would have gone 100% OEM. I got every component GM OEM including Cam Gears and OEM Balance shaft set for $380.64. Crate engine Warehouse gets $625.00 for what I purchased. That made it easy to afford all ARP bolts to go with it
Timing chain set
LE5 2.4 Timing Chain Deluxe Set LE5DTCKIT
Balance chain set
L61L35bck Balance Shaft Chain Kit for 2.2 and 2.4 Ecotec Engines
Old Jan 20, 2018 | 05:29 PM
  #220
My balance shaft chain and timing chain is new. The only thing used are the cam gears.
  #221
And the tensioner wasn’t even in yet in that picture.
Old Jan 21, 2018 | 12:37 AM
  #222
Henry3959's Avatar
If I hadn't received mine for $75 for the pair I would have purchased a set from ZZP. Mine are just too worn.
Old Jan 21, 2018 | 06:50 AM
  #223
jdbaugh1's Avatar
I replaced my timing gears near 100,000 miles with the timing chain but honestly they didn't look worn at all. Hard to tell the difference from the new units. I use M1 and don't have VVT though, don't know how that affects it.
Old Jan 23, 2018 | 08:18 PM
  #224
Henry3959's Avatar
Are you running the Phenolic spacer between your head and intake? I'm thinking about it but with an Auto my SC is already right against the front end.
Old Jan 23, 2018 | 09:21 PM
  #225
Yes I am. Had to cut a big section of metal out to clear the pulley.
